How does one remove the right side CV joint/half shaft?...
First jack the car up, and then remove the wheel. Then you need a 36mm deepwell socket to remove the large axle nut.Then remove the 3 carrier bearing bolts that support the axle.Last but not least remove the 3 bolts the hold the ball joint on, this will allow the brake and strut assembly to be moved out far enough the get the axle out.
Good Luck
Jason
Good Luck
Jason
Re: How do you go about removing the 3 carrier bearing bolts?
Originally posted by G3Max
Its kinda tight. What tool did you use?
Kevin
Kevin
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
