RPMs jump wildly...car often stalls...
Hello...any help is GREATLY appreciated...
I have a 97 Max SE -- Auto with a hair under 100K miles.
For a few weeks now, my car has been wonky...I start it, it revs around 12-1300 RPM, and will idle normally at temperature. However, more often than not, the engine RPMs will wildly fluctuate up and down, sometimes cutting out altogether (sometimes, it'll hang on around 200 rpms, then jump right back up to 800).
Its getting to be dangerous...When this first happened, it was confined to reversing and slow starts, but now, even at highway
speeds the car will sometimes feel like its pulling (RPMs will drop, but, not from 2500 to 500, more like 2500 to 2300, still scary
OK, since this problem started, some codes have appeared:
Front Right Heated O2 Sensor (twice)
Knock Sensor (three times)
Mass Air Flow Sensor (once)
Rear Heated O2 Sensor (once)
IDEAS? THOUGHTS? HELP ME!!!
I love my Max, and owe far too much to let it suffer like this!
thanks all!
G.
)OK, since this problem started, some codes have appeared:
thanks all!
G.
Re: Re: RPMs jump wildly...car often stalls...
Originally posted by MDubya
Whens the last time you tuned up your Max, Plugs(15.00plugs), Wires, fuel filter etc.?
PLUGS -- last summer?
WIRES -- ?
FUEL FILTER -- ?
mine was a similar situation... it would stall out on occasion, usually when just started or just up to temp, but always random. daniel B martin insisted it was the coolant temp sensor... he was right. anyways, some days or drives would be fine, others it would stall (always at a bad time). i did my fuel filter first, and that did not help, i doubt that is the problem with yours either. search for coolant temp sensor, and try doing the voltage checks that Dan mentions, it cant hurt. goodluck
Hall
Hall
Originally posted by 97MaxSE
Here's an idea.....take it somewhere & let them tell you what the problem is?
Thanks for all the replies!!! Some more information
Hello everyone, and thanks for the replies.
Some new information about my car which I thought might help:
I had a stuck injector replaced last year...
I put in a new air filter last summer...
When a had a similar problem to this in the Autumn (although, far less so), the Nissan dealership said that it was simply a loose wire -- but, they never let me know which one...thoughts?
again, much appreciated!!!
best,
flo_boy
best,
flo_boy
Re: Thanks for all the replies!!! Some more information
about the coolant temp sensor...
FIRST clean the throttle body, its easy and cheap... if that fixes it, you are lucky, and it should be done anyways..
if that doesnt work, it still sounds similar to my problem.
check the ECU for any codes, and see what COULD be the problem.
the coolant temp sensor controls how rich the car runs at different temperatures. doesnt effect the engine temp. when its cold, its gets more gas, the sensor will screw up, and basically stall it out by running it lean or rich. it was a long stretch to believe it, but it sure worked, after stalling every other day, it hasnt stalled again for months since the fix. give me a few more details about your prob, and i'll look around and see what it could be. i owe Daniel B Martin for this one, i miss him
Hall
My first thread on Coolant temp sensor
Another post about the sensor from me
Hall
Re: Re: Thanks for all the replies!!! Some more information
SuDZ
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
