Anybody with cai, IMMEDIATE HELP!
Hey you all. I just got my Place Racing Cold air intake put on today. I drove home and loved it, it was just awesome. Well, I let it sit for about 20 minutes and went out again. Right after I started it, i drove like 10 feet and let off the gas, and my car shut off. The RPMs went way down, and just quit. I just shift into neutral, and continue doin it.
Has any of you guys had a problem with this. Could it be something with the o2 sensor, sw autoworks told me that I probably will need to put some silicon on it to make it stick. Any ideas?
Thanks for the help
Thanks for the help
just a note
I forgot to add that the reason i am in such a big deal is I HAVE to pick up my parents at the airport tomorrow and bring them from phoenix to tucson, they are flying in from wisconsin. So this is pretty important. Thanks guys, youre the best.
*desperate
*desperate
Re: just a note
*desperate
*desperate
check the connector to the Mass Air Flow make sure it is all the way in (Try removing it and reconnecting it). also check all the hose connections and the air temp sensor... Also did you use the o-ring that was on the MAF because air leaks can upset the MAF.
And as usual this is IMHO
does your CAI have a hole in the bottom? also, did you make sure that all sensors were connected? it's a Mass Air Flow Sensor problem...but i can't quite diagnose it...there's gotta be a leak somewhere after the MAF or somewhere in the intake...also, make sure the Air filter is attached correctly...
Maxima_Joe
Nov 25, 2015 08:19 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
