Help: Nokya Headlight Harness
Old Feb 15, 2002 | 07:36 PM
96max's Avatar
Hi, anyone know how to install this thing? I just got it in the mail along with a set of Nokya Arctic Purples. The bulbs work great on the stock harness. I only installed it on the stock harness case I couldn't wait to see how it would look. Now I need to find a way to install this headlight harness. Any help would be appreciated. Here's a pic of it if it helps.
http://www.spwusa.com/Images/Products/nok9103.jpg
Old Feb 15, 2002 | 07:55 PM
spiff56747's Avatar
Re: Help: Nokya Headlight Harness
There are some directions on www.maximadriver.com for installing the APC wiring harness, I imagine this thing is similar. BTW how much did u pay for the Nokya one?
Old Feb 15, 2002 | 07:59 PM
96max's Avatar
Yeah, I read about the APC one, its different. I think this one might require splcing. Not really sure how to do that though. I got it from Alex at southeast autoworks. I think I paid $14 for it.. forgot.. there was a post in the parts section awhile back.
Old Feb 15, 2002 | 08:18 PM
Miguel97GLE's Avatar
Go to Home Depot or somewhere similar and buy Female bullet connectors. It's a really easy install, just clip the wires up by the stock housing, strip about a half inch of insulation off each one and apply the connectors. Just pay attention to which wire is which and everythings cake. Wrap with electrical tape and you're done.
Miguel
Old Feb 15, 2002 | 08:20 PM
NYCe MaXiMa's Avatar
I got some APC wiring harness.... I don't see why it would need splicing or why it's different... should be the same no matter what brand it is. Mine is just covered with a yellow protective thing, I guess to protect it from heat and stuff.... I got it used too.
Anyways, I can't distinguish it from that pic.. if u can open it up and unfold it, maybe someone can compare it and help you out.
Basically it should look like this, consist of the following things:
-2 socket plugs, like the ones that the bulbs should be plugged into.
-2 ground wires.. (have a small metal hoop-like thing at the tip)
-2 more wires that also have hoop thingies at the end, (these go to the battery..)
-2 square/box units...
sorry for the bland terms lol.. best way i can describe it from what i remember....
there is a diagram on Maximadriver.com........... it's pretty self explanatory. the metal hoop/ground wires should be placed on a spot where there is bare metal... I and most other people use the metal things on the frame... if u can look at the maximadriver.com diagram you will see what i'm talking about... just take off the screw and put them over, then tighten it up real well...
Old Feb 15, 2002 | 10:11 PM
96max's Avatar
thx for u'r help, i'm gonna head over to home depot tomorrow. This harness is slightly different from the APC one, it does not connect to the battery. Sorry about the pic, I don't have a digital camera, that link was just off a site that sells the same wiring harness.
Old Feb 15, 2002 | 10:18 PM
Oh, I see what you are saying, now that i look at it again, it kind of looks different too, lol. Just too little stuff, mine was a whole load of wires. Good luck, just don't run those Nokya headlights on stock harness for too long, don't want to burn it out.
Old Feb 15, 2002 | 10:29 PM
96max's Avatar
Yup, thanx. Those Nokya's are pretty bright though. Is it just me or are they brighter from a distance. Up close, they are very white and do not look too bright, but from a distance they are very bright and purplish in colour.
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
