Help: Nokya Headlight Harness
Hi, anyone know how to install this thing? I just got it in the mail along with a set of Nokya Arctic Purples. The bulbs work great on the stock harness. I only installed it on the stock harness case I couldn't wait to see how it would look. Now I need to find a way to install this headlight harness. Any help would be appreciated. Here's a pic of it if it helps.
http://www.spwusa.com/Images/Products/nok9103.jpg
Re: Help: Nokya Headlight Harness
Yeah, I read about the APC one, its different. I think this one might require splcing. Not really sure how to do that though. I got it from Alex at southeast autoworks. I think I paid $14 for it.. forgot.. there was a post in the parts section awhile back.
Miguel
I got some APC wiring harness.... I don't see why it would need splicing or why it's different... should be the same no matter what brand it is. Mine is just covered with a yellow protective thing, I guess to protect it from heat and stuff.... I got it used too.
Anyways, I can't distinguish it from that pic.. if u can open it up and unfold it, maybe someone can compare it and help you out.
Basically it should look like this, consist of the following things:
-2 socket plugs, like the ones that the bulbs should be plugged into.
-2 ground wires.. (have a small metal hoop-like thing at the tip)
-2 more wires that also have hoop thingies at the end, (these go to the battery..)
-2 square/box units...
sorry for the bland terms lol.. best way i can describe it from what i remember....
there is a diagram on Maximadriver.com........... it's pretty self explanatory. the metal hoop/ground wires should be placed on a spot where there is bare metal... I and most other people use the metal things on the frame... if u can look at the maximadriver.com diagram you will see what i'm talking about... just take off the screw and put them over, then tighten it up real well...
thx for u'r help, i'm gonna head over to home depot tomorrow. This harness is slightly different from the APC one, it does not connect to the battery. Sorry about the pic, I don't have a digital camera, that link was just off a site that sells the same wiring harness.
Oh, I see what you are saying, now that i look at it again, it kind of looks different too, lol. Just too little stuff, mine was a whole load of wires. Good luck, just don't run those Nokya headlights on stock harness for too long, don't want to burn it out.
Yup, thanx. Those Nokya's are pretty bright though. Is it just me or are they brighter from a distance. Up close, they are very white and do not look too bright, but from a distance they are very bright and purplish in colour.
doctorpullit
10-28-2019 10:58 PM
magiconthetire
10-26-2015 09:03 PM
