Xenon Lights What to use?
Re: Xenon Lights What to use?
Originally posted by SOHI
Hey i was thinking of getting xenon Headlights which company should i get them from? And do you know the size for the bumper ones. i would appreciate your suggestions.
I basically bought bulbs to white-out everything inside & out. I'm at work now, but I'll let you know the exact bulbs that I used & post some pix later.
Here's what I know off the top of my head for 2002 models only:
9005 - High Beams 65W
H-3 - Fog Lights 55W
194 - Clearance bulbs
194 - Door bulbs
194 - Trunk light
921 - Backup light (reverse)
3175 - Dome bulb (it fits)
G
PIAA
Consider the PIAA H4 Xtreme White. The input power is the same as stock but you get almost twice as more brightness as stock bulbs. Check them out:
http://www.piaa.com/h4bulbs.html
Originally posted by DooBall
im never buying piaa bulbs (h4) again. they die out randomly.
i just got new eurolite xenons. i think their alot brighter then the xtreme whites i had
How hard is it to replace the stock fogs.Do you have to take the lights completley apart to change or are they quick change like every other bulb on the car.Have not heard alot of good things about PIAA so I think I will give Xenon's a try.
i wasnt talking about 'true' xenons. i just call those cool thingies hid.
i meant xenon filled bulbs, and i think eurolite makes pretty good ones. their bulbs are always very bright and white. i dont know if their safe for my headlights though. forgot to read the packaging
but they work, and their bright!
piaa bulbs arent bad, but i dont ever plan on buying their h4 bulbs. the super plasmas look good on my side markers.
and changing the fogs is fairly easy. It just takes a minute to figure out what your looking for under the car. but after the first time, you could probably swap a bulbs in minutes.
but they work, and their bright!piaa bulbs arent bad, but i dont ever plan on buying their h4 bulbs. the super plasmas look good on my side markers.
You get them at http://www.customaxima.com or you can get them at http://www.courtesyparts.com
Greg at customaxima has them for a better price. I might add that it is a GREAT idea to put a sh** load of silicon around the edge where the casing meets the housing. Once you get water in there forget about it.
PIX & INFO ON MY WEBPAGE
Just installed XENONS!!! Check my post below for a link to my webpage w/PIX & info...
CLICK HERE FOR THREAD
Later,
G
Later,
G
Originally posted by TRUblu2K2
sure enough I was a slack *** and didn't put any silicon on mine so now I got lots of moisture in there I'm gonna try all I can to get it out before I get another set
so i should try to stay away from the oven?what other methods should i use
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
