Crackling noise from the rear
I've got a 99SE/LE, and for the past year or so there's been this constant (and very annoying) crackling noise coming from the rear when I drive SLOWLY over uneven surfaces, as if the frame is crackling. I asked a mechanic and he said it may be the strut - but the car doesn't make any noise going through bumps, only when going through uneven surfaces - like when you go up a driveway at an angle, you know the frame is going to bend a little...
Any suggestions? Should I ask my dealer to "lubricate" the chassis (whatever that's supposed to mean).
Re: Crackling noise from the rear
better have them looked at just in case.
Re: Re: Crackling noise from the rear
Originally posted by WoPhatMax
i have a 95 GLE and had the same cracking noises. the noise on my car was due to both rear rotors being cracked. they only made the noise going slow on uneven surfaces (i.e. sloped drive thru window, driveways, etc). never heard the noise during normal driving. nissan service tech was amazed that the rotors had not blown apart - i saw them, they were bad
i read one of the notes about the lowering springs making those noise, any other comments on the possible cause?
thanks.
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
