Hooking up air/fuel rat guage....
Re: Hooking up air/fuel rat guage....
Originally posted by Dahnryman
if im not mistaken there are 2 wires on the front o2 sensor....but which one do i splice into....black or white?
can anyone help me with this befor i cut the wrong wire?
(some other member posted it)Click me if I'm LAZY
Re: Re: Hooking up air/fuel rat guage....
Originally posted by Chunger
This has been asked before... but here's a pic lazy!
which one? that still did not answer his question!!
Originally posted by rguida
uh...I didnt cut into either of those...i used something like #57....which should be the rear o2 senson thats on the catalytic converter???? (95-96)
not to sound dumb....though i have never done this befor what is that a picture of?....is it the side of and ecu....if so arn't 97 different form 95-96?
Originally posted by mtrai760
You could just use the stripped shielded wire off the wires for the O2 sensore by the front bank and make this much easier on yourself.
actually, if you are tapping into the o2 sensor under the hood, there are 3 wires. on the plugs to the sensors under the hood, (there are 2- a front and a back) there's a red, a white, and a blue. the rear sensor has the same scheme, just a stripe on each wire.
you need to tap the blue one. i tapped both sensor plugs and got the same results from each one.
i actually got a seperate o2 sensor to install specifically for running my a/f gauge. it's an NTK part #21000. it has a single wire and should be more accurate than piggybacking the ecu. this might be something to consider. it's not expensive at all. the sensor only costs about $25 and you can get a bung to weld into your exhaust for about $6 from summit.
good luck!!
good luck!!
Re: Re: Re: Hooking up air/fuel rat guage....
The picture is of the harness side (hence the HS on the pic)... in otherwords, the way you would see it on the ECU. It's easier to do than running the wire from the engine compartment IMO. Just remove the plastic cover on the passenger side foot area. Take care with the harness/ECU though and keep in mind that you have to fit everything back under the clear plastic piece of the harness.
