How do I get the Antenna to not come up w/cd player?
Old Apr 15, 2002 | 12:35 AM
Nismo's Avatar
I just got my pioneer 6400 HU installed and I dont like the idea about the antenna popping up everytime I turn it on. Is there some way to have it not come up?
Old Apr 15, 2002 | 12:40 AM
jdmmax's Avatar
Re: How do I get the Antenna to not come up w/cd player?
depending on how the head unit is set up there is a way on my alpine radio that allows that to happen. either that or you head unit was not wired up right
Old Apr 15, 2002 | 03:49 AM
Coldboot-SE's Avatar
Not necessarily
jdmmax,
Some models of radios don't have dedicated antenna leads and installers use the remote turn on to power the antenna, I know as I have a Pioneer 7200, to remedy the situation I installed a switch to to open the antenna's pwr (not to the amps!, bad juju)
The downside is everytime I play the radio, I manually have to raise the antenna, and lower it prior to turning the car off, otherwise the antenna stays up,....not the installers fault as it's a bad design and there aren't many options.
Dave
Old Apr 15, 2002 | 10:24 AM
jdmmax's Avatar
Re: Not necessarily
Originally posted by Coldboot-SE
jdmmax,
Dave
ahaha yeah that was another posibility that i was thinking about but i have always worked with alpine products so yeah sorry for any consion.
Old Apr 15, 2002 | 07:27 PM
MIXXMAX's Avatar
Only certain models of head units have an internal switch for power antennas when only the tuner is switched on. Years ago, I also ran into this problem of the antenna being up at all times when my stereo was on. But, later, after buying a new Kenwood headunit, the unit had a switch built inside where when the tuner was on, the antenna would also turn on. And, if I switch sources, such as to the CD, the antenna would turn off. The only way around this, I believe, if your antenna stays on all the time, is maybe just hook up a switch to its lead to turn off and on to your own liking when your stereo is powered.
Old Apr 15, 2002 | 09:27 PM
WizzaMax's Avatar
Re: Not necessarily
jdmmax,
That's okay...I used the power from the antennae to power the accessories lead to my Kenwood amps...(2 small ones) and the mast goes up and down regardless of whether or not the radio is on or tape or cd is playing. I am not certain if I remove the lead and connect it more safely, whether it will right itself or I may have messed up the antennea wiring.
Old Aug 28, 2002 | 01:36 PM
Minimalmaxima's Avatar
MIXXMAX, what Kenwood unit did you get and how did you hook it up? I have only the Kenwood KRC-207S cassette deck with changer controls. Do you think there is a way to hook this thing up so that it will leave the antenna down when the cassette player or changer is on? When I had the double-din Clarion head unit hooked up that was one thing that I loved about the system.
Old Aug 29, 2002 | 08:01 AM
Unibomber's Avatar
who cares what unit u have just hook a switch up to the antenna wire
Switch on the antenna goes up
Switch off the antenna goes down
thats how i did mine
Old Aug 29, 2002 | 10:41 AM
NYCe MaXiMa's Avatar
I got the same problem with my 9200 Pioneer
it's the way the freakin thing is designed..
I am going to wire up a switch to it.
stevesmax
Dec 17, 2020 11:57 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
