Redline MT prone to leak?
Old Apr 15, 2002 | 02:00 PM
zboy's Avatar
I read one one of the writeups about Redline MT90 that since it was a synthetic oil, it was very slowly leaking out of the transmission case (it wasn't leaking enough to drip). I was wondering if this was a common problem? Or is it something I shouldn't bother worrying about?
I was thinking about replacing my transmission oil in a month or so..
-zach
Old Apr 15, 2002 | 02:02 PM
SuDZ's Avatar
Re: Redline MT prone to leak?
-zach
I have had mine in since October or so. I have had no leaks and I am not low at all. I see no problem with it. I remember the write up and it made me nervous but so far so good.
SuDZ
Old Apr 15, 2002 | 03:12 PM
Chunger's Avatar
My other car is a Hybrid
Don't believe everything you read... sometimes things just occur cuz they're getting old and it could be a coincidence.
I've been using Redline MTL for the time my car had about 6K miles... I now have almost 45K... I haven't had any leaks (even with 1 MTL change).
Old Apr 15, 2002 | 05:37 PM
DSimple1's Avatar
I just had my tranny done with Redline MT90 about a month back. Did a road trip to cali from utah, still no leak, shifts great.
Old Apr 15, 2002 | 06:15 PM
RalphW's Avatar
I'm planning on changing my manual transmission oil to RedLine in my 2Y2 SE but when I pulled up their site, I wasn't sure which product and how much to buy. Any help please.
RalphW
Old Apr 15, 2002 | 10:23 PM
y2kse's Avatar
RalphW
The 2Ks and 2K1s use MT-90. I'm pretty sure the 2K2s use the same thing. But check your owner's manual if you want to be certain.
I've used MT-90 for about 20K miles and my tranny hasn't leaked yet. And yes, it shifts great.
Old Apr 16, 2002 | 06:06 AM
dwapenyi's Avatar
Here you go;
http://www.greghome.com/Greg's%20Garage/2002MaxSE/MT-90.htm
Enjoy your ride
DW
RalphW
Old Apr 16, 2002 | 08:47 AM
Blackgums100's Avatar
Synthetic
is generally thinner, so some do not recommend it in older cars. However in a well made Nissan it shouldn't be a problem. Now it was a problem when I put it in my Wife's 80,000 mile 98 Durango, damn should have bought an import.
Old May 16, 2002 | 03:59 AM
john2002max
RalphW
The 2K2 uses MT 90, which is a 75W90, this is what is called for in the owners manual. I changed mine in my 2K2 and it works great! The redline MTL is a little bit thinner(70W85). I would stay with the same weight as the owners manual calls for.
Old May 16, 2002 | 05:45 AM
speedtrip's Avatar
I made the switch to redline at 90,000 miles. I hate myself for not doing it sooner. I changed the engine oil a couple days ago and I noticed no signs of any leaks or weeping from the transmission.
Old May 16, 2002 | 06:28 AM
Hobert's Avatar
If I change my tranny fluid, where can I dispose of it? A local auto parts store takes engine oil, but I forgot to ask them if they take other fluids.
Old May 16, 2002 | 06:37 AM
dwapenyi's Avatar
I find it very odd that the newer technology 6 speed only holds 3 quarts of tranny fluid, if that, yet my older generation 5 speed holds 4.5 quarts. Of course my tranny has a history of bad bearings issues and the 6 speed is still too new. Hmmmmmmm.
DW
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
ac max 92
Sep 17, 2015 07:35 AM
