> Max Stalls...wt....? <
My MAX stalled this morning, again, as soon as I stopped at a STOP sign, and didn't start quickly too
, but when the car warmed up, it seemed fine. MIL light didn't come on.
This problem started a few days ago for the first time. About three weeks ago I replaced Knock Sensor and PCV valve, cleaned Throttle Body (MAF sensor was clean). I USED search function..., maybe someone has some new info/update in order to solve this problem
Don't let your bro down
Thanks guys, I appreciate it.
, but when the car warmed up, it seemed fine. MIL light didn't come on. This problem started a few days ago for the first time. About three weeks ago I replaced Knock Sensor and PCV valve, cleaned Throttle Body (MAF sensor was clean). I USED search function..., maybe someone has some new info/update in order to solve this problem
,Thanks guys, I appreciate it.
Fuel Filter
Idle Air Control Valve - Might be lazy, you can clean it out just like the throttle body. You have to remove it and disassemble it.
Idle speed adjustment? Check the default settings. Without the TPS connected you should idle at around 700. If your way to low, the IACV is working overtime to keep your car idleing correctly, combine that with the face that it may be lazy, and there's your stalling issue.
Originally posted by JeepRage
could be another case of the Coolant Temp. Sensor. Search for it and check up on it. I had a good post about it 7 months ago or so. My car had sort of similar probs.
Goodluck, Hall
Goodluck, Hall
I have a 95gxe and had the same problem, my max would just shut off with out notice and start back after a few tries(embarrassing at stop lights), get the coolant temp sensor replaced, the part only cost about $40.00(about the same size as a spark plug) and can be done within a 1/2 hour. I got mine replaced, no more problems.
hope it helps.
Originally posted by MAX95RUS
That's it! I am going to get a new coolant temperature sensor!
Another thing I noticed today, when car was warming up in the morning, fans would turn on and off for a few seconds
my max did this also each time I started it. Replacing the coolant temp sensor will fix all this.
bbrown
Originally posted by njmaxseltd
Fuel Filter
Fuel Filter
SuDZ
did any of you guys have a hard time starting from a cold start. Meaning the engine would just turn and turn but no start. Someone said it could be a camshaft position sensor problem.
I had this problem in the past in which the car wouldn't start on certain occassions like described above. And then other times I would come to a stop and watch my idle go lower and lower, the car would shake like it was going into rough mode and then finally stall.
Your right though, it is embarrassing when ur car won't start up for after a couple minutes. And your stuck there. Especially in rush hour.
Re: > Max Stalls...wt....? <
UPDATE!!!
Replaced coolant temperature sensor - $28 total
Took my Max for a test-drive and it didn't stall
Checked fans, they didn't turn on while car was warming up. When car warmed up, both were spinning.
Well, will see what happens, I hope replacing coolant temp. sensor solved this stalling problem. If Max will stall again I'll let you know.
What do you think guys, should I reset ECU just in case?
Thank you all for your replies!
Re: Re: Re: > Max Stalls...wt....? <
Originally posted by Jepht20
howcome you got your part so cheap? i payed 41.03+tax so it was like 43...that's a pretty big difference in price for one lil part don't you think?
This is how much I paid. I bought it from NISSAN.
Re: Re: Re: Re: > Max Stalls...wt....? <
Well I don't know
Well I don't know
I paid $40.00+ for mine as well, whatever, as long as the max is running smooth and I don't have the headache of the problem reoccuring I am satisfied.
bbrown
did you guys put them in yourselves? if so, was it easy? i'm going to attempt to do it this weekend and it doesn't look like a complex part...so hopefully it's fairly easy. thanx for any suggestions
I'm having the same problem too. I was at a light on sunrise highway today checking out this cute chick next to me in an eclipse and my car just stalled! I was soooooo embarassed! It started up after the second try. It kept stalling on me the whole way home. That is one of the worst feelings in the world. I'll replace the sensor and let everyone know if it worked. I really hope it works. Thanks everybody.
Originally posted by Wht98SE
My SE simply idles around 500 rpm in D, sometimes as low as 400 rpm, any causes for such an oddly low idle?
This is a '98 SE w/ Auto. Trans and 75,000 miles
48.50 installed for me @ a local mechanic
[B]Fuel Filter
Idle speed adjustment? Check the default settings. Without the TPS connected you should idle at around 700. If your way to low, the IACV is working overtime to keep your car idleing correctly, combine that with the face that it may be lazy, and there's your stalling issue.[B]
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
