18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
Old May 13, 2002 | 04:30 PM
seven's Avatar
anybody have this setup?
Old May 13, 2002 | 10:03 PM
MAC's Avatar
MAC
Re: 18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
you'll be ok.
I've got 18x8 w/ 37 off set. No prob. It's only 8mm more.
Old May 14, 2002 | 12:11 AM
Chunger's Avatar
My other car is a Hybrid
I think MaxBandit has 245s and he said it rubbed slightly at full turn.
Old May 14, 2002 | 01:46 AM
MaxedBandit's Avatar
Re: Re: 18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
Yup, I'm running 18x8 with a 45 offset with 245/40/18's and it does rub when the steering wheel is fully engaged.
Old May 14, 2002 | 06:31 AM
seven's Avatar
Re: Re: Re: 18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
so if I run 235 i shouldn't have any rubbing problems right?
thanks guys
Old May 14, 2002 | 10:16 AM
Chunger's Avatar
Re: Re: Re: Re: 18 x 8" wheels with 235/40 tires and 45mm offset: will I have rubbing problems
thanks guys
There's no way for us to know unless you try it (unless someone else has and post re: it)... I'm sure it will be more than liveable if it even rubs at all.
Old May 14, 2002 | 10:58 AM
Supa Lao's Avatar
I'm running this setup and no problems what so ever. Your rear tires just sit in more from the fender.
Matt93SE
May 24, 2019 02:58 PM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
