Please Post What Brand Of Oil & Coolant You Use And Why...
Old May 23, 2002 | 10:18 PM
FJC's Avatar
FJC
I know this topic has been beaten but I couldn't find one concentrated thread on fluids.
Please post oil, coolant and reasoning.
Old May 23, 2002 | 10:34 PM
max808's Avatar
pennzoil and prestone. i used them because it very available. and also i like the yellow packaging.
Old May 24, 2002 | 01:18 AM
karguy's Avatar
Re: Please Post What Brand Of Oil & Coolant You Use And Why...
AMSOIL, I use it because the company backs up it's claims with test results. I'm from the old school, don't just tell me but prove it. On the AMSOIL oil container they show results of testing with their competitors, by name and oil range. If this was not accurate don't you think AMSOIL's competitors would sue them out of business. I have yet to do research on which coolant I'll use when I flush my cooling system.
Old May 24, 2002 | 06:54 AM
iwannabmw's Avatar
Amsoil for the engine oil and Zerex for the antit-freeze/coolant. Amsoil because it has proven itself over the past 30 years and is worth it for my car. Zerex because it has a low corrosivity and won't "attack" the components in the cooling system as quickly as some of the others.
Old May 24, 2002 | 08:01 AM
njmaxseltd's Avatar
Amoco or Mobil in the gas tank
Amsoil in the engine
Penzoil in the tranny
Nissan in the cooling system - I haven't changed it yet.
Oh and me behind the wheel.
Old May 24, 2002 | 09:03 AM
xHypex's Avatar
Amsoil in the engine (I've used Mobil 1 and Royal Purple before)
Redline in the transmission
Toyota Red in the cooling system
Ford Dot4 Brake Fluid
I like using good fluids, but I also prefer to not have to replace them as often. The Amsoil and Toyota Red are known for being better fluids for extended drain intervals while still being an effective fluid (i.e. not breaking down). I'm running 10k oil drain intervals with the Amsoil, and the Toyota Red is supposed to be good for 2 years rather than one. I can always change the fluid early should I feel the need.
-hype
tnewbs
Aug 28, 2015 10:15 AM
4 door GT-R
Aug 22, 2015 07:50 AM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
