I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
I am coming up on an oil change interval and just got the car. It runs perfect and does not leak. Think I'd be ok with Amsoil?
I actually used to work for Pennzoil and we refrained from using synthetic in anything over 70K, this was 7 years ago...
Since my car is relatively newer and runs fine, I should be ok???
Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
I've heard there is nothing wrong with switching. You may want to skip using any "cleansing" oils (I think they have some kind of treatment), because they could compromise your seals. I plan on switching in July...
The old problem of sythetic not "swelling the seals" is also largely BS.
Use the same viscosity and you'll be fine.
-RMB
Re: Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
Originally posted by rmb
You can switch to whatever synthetic you want whenever you want. It's stupid old fairy tale that you have to wait xxxx miles for the engine to break in. Porche's and corvettes come stock with Mobil 1 so I wouldn't worry about it.
-RMB
-RMB
Re: Re: Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
Originally posted by Turd Ferguson
thanks for the enlightening info. but why do people use viscosity other than 5w30?
-hype
