Why do bigger rims yield a harsher ride?
Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by saggleman
the lack of cushion from less air volume in the smaller tires.
Not only less air but less side wall means less rubber = Harder ride.
Re: Re: Re: Why do bigger rims yield a harsher ride?
Originally posted by njmaxseltd
WOW - 1st post was a good one! Informative and straight to the point!
i can ride on tires with no air with 20s. for like a week i didnt have any air in one of my tires and i didnt know until i was checking the pressure... and the ride difference isnt as dramatic as people act..
i believe, if I remeber correctly, in order to maintain the "similar" ride you would have to increase the width of the tire as much as the rim size....for example, if you get 19's, (lets say 3 inches over stock) then you would have to increase the width by 3 inches to compensate. however in many cases this is unrealistic, and you would rub against the wheel well. so you might end up only getting 1-1.5 inches wider if your lucky. this is all conjecture so dont quote me on this.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
beat me to it...dam low profiles....
