Cruise problems
Old May 29, 2002 | 09:56 AM
Damion's Avatar
Cruise problems
Ive searched for an hour and no one has the same symptoms as i do.
I turn the cruise on the light on the switch comes on, push the set button cruise comes on then goes off after a second (the green light in the gauges also comes on and goes out but doesnt flash). I know it does work cause it has worked 2 times before but i have no idea whay it would work those times and then now any help please?
Old May 29, 2002 | 03:52 PM
ninezero's Avatar
Re: Cruise problems
I had something like that to :changed the ascd controle unit.
Junk yard or car-part.com
Old May 29, 2002 | 04:01 PM
«§»Craig B«§»'s Avatar
when I was fixing my cruise, I found that when I had a bad cruise actuator in, the green light on the gauges would come on for a few seconds but then go off after the speed dropped about 10mph or so below what I tried to set it at
Old May 29, 2002 | 06:32 PM
Damion's Avatar
Craig ,
where is the main control unit and where is the relays (if there are any fo rthe cruise) mabye one of thos are bad i tested the actuator and it was fine
Old May 29, 2002 | 08:23 PM
Originally posted by Damion
Craig ,
I just posted this a few times last week, but oh well
if you remove lower dash on drivers side (9 or so screws), look to the right of the steering column, gray plastic box is the door lock timer, directly behind it is a metal box that is the ASCD controller (automatic speed control device=cruise)
one relay under the hood
Old May 29, 2002 | 08:33 PM
DanNY's Avatar
Ad·min·is·tra·tor
he's saying you didn't search hard enough..
Old May 30, 2002 | 04:05 AM
Damion's Avatar
ok ill check that if it ever decides to stop raining out. Craig while im there ill confirm the wire harness connector to disable the DRL if you still would want to post it on your site
Old May 30, 2002 | 09:37 AM
cool, I've been meaning to add that to the site, but haven't done many updates recently
I will probably do it soon
Old May 30, 2002 | 11:17 AM
Damion's Avatar
Im probably gonna mess with that tomorrow so i can confirm the wire colours
Old Dec 3, 2002 | 07:00 PM
arges's Avatar
Re: Cruise problems
That symptom sounds like the actuator ( I know, when I installed a new one and forgot to reconnect the harness, it did the same thing). YOu can get a replacement at a slavage yard for about $15.
Stephen
Old Dec 3, 2002 | 11:14 PM
The Sleeper's Avatar
my cruise just doesnt work at all anymore. the main on/off switch lights up, but the control buttons don't do anything. help ?
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
homewrecker
Sep 24, 2015 07:01 PM
