Errrgg...dash won't come apart...
Old Dec 3, 2000 | 12:54 PM
maxspeed5's Avatar
or at least I can't make it. I need to re-route my cd changer control (previous owner stuck it on the dash and it is ugly as sin). I got around the sifter up, the ash tray out, but then the vents/clock would not come out. How much force do it need? Tried prying, pulling, and cursing it -- none worked. I know how to get it out (via Haynes manual and Crutchfeild), but am afraid if I force it too much that I will break it. Please help...
Old Dec 3, 2000 | 01:00 PM
Daniel B. Martin's Avatar
Try the Install Doctor at ...
http://www.installdr.com/
Click on Install it yourself.
Click on Nissan.
Click on Maxima.
[Edited by Daniel B. Martin on 12-03-2000 at 03:46 PM]
Old Dec 3, 2000 | 01:11 PM
dch95's Avatar
errrgg@*&%$?!
The vents,hazards,clock and defroster is all one panel. The climate control (A/C) panel is not part of that so don,t pull/pry on that part. I pulled the vents off by prying outwards at the point of the defrost switch or the hazard switch. I have a 95 gle so it should be the same. After that you should see that the stereo and A/C panel are screwed in.
Old Dec 3, 2000 | 06:13 PM
NickStam's Avatar
Re: errrgg@*&%$?!
See if this helps,
Old Dec 3, 2000 | 06:37 PM
Nathan's Avatar
To remove the upper part which houses the clock, warning signals, and vents you have to pull up on the below part which houses the coin, radio and a/c controls. The first time I tried to remove the dash I got fed up and tugged on the middle part and the top part just poped up. For more info click on my website to the left and look under shoptalk for pics. Good luck.
Old Dec 3, 2000 | 07:50 PM
GarthG's Avatar
To get the clock part of mine off I normally use the top of the little inlet for the clock to lift it up, then when it gets above the clips holding it in, I pull straight out. . . Works well for me.
Old Dec 5, 2000 | 01:37 PM
maxspeed5's Avatar
Thanks for all the info...
I will attempt it again this weekend...
Old Dec 5, 2000 | 03:34 PM
Ryan93SE's Avatar
i did this yesterday.....
you have to push down and toward you on the ac vents..then you will see two screws and the rest is easy.... it took me 8 hrs but everything is in and sounds great
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
