Fuel Pump Pressure On 92 Se ???
Old Jun 6, 2002 | 06:18 PM
wojtekj's Avatar
I have a problem with the acceleration as well as engine shut-downs, and after trying everything (cleaning KS terminals, tune-up, etc.) I've decided that a fuel pump might be defective.
I want to know what is the fuel pump operating pressure, and what would be the best way to check it.
Old Jun 6, 2002 | 07:10 PM
Nismo87SE's Avatar
Re: Fuel Pump Pressure On 92 Se ???
It should be at 43psi at idle and 36psi for about 10 secs after ignition is turned off.
Old Jun 6, 2002 | 07:44 PM
Nismo87SE's Avatar
It should be at 43psi at idle and 36psi for about 10 secs after ignition is turned off. You can put a Tee in the fuel line from the fuel filter to the fuel rail. Any pressure gauge with a 0-60psi or more range will work.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
