CV boot replacement
CV boot replacement
Okay so today the dealership tells me that both front cv boots are cracked. He said i have about a month or so to take care of it and that to repair them it was going to be about 175 a piece plus 220 labor. I've heard that it can be done cheaper, anyone have suggestions? I need help bad and I don't have that money......
You can get brand new (not remanufactured) axles for about $125 per side. You can install them yourself too. It's not that hard.
www.raxles.com
They rock!
www.raxles.com
They rock!
Well I'm fairly mechanically inclined but I don't know much about the axel/wheel area. Mostly electrical and engines. So can I do this at my house and what do I risk messing up. Where can I get directions?
Re: CV boot replacement
Try taking it to a local shop instead of the dealer. I bet you cut that price in 1/2. The replacement boot is only a few bucks. The rest is labor. The dealer gets like 80/hr for labor and they go by the book. A local shop might do the job pretty quick and only charge you for the time it actually took to replace the boots.
Boots outer $11.00 each at carquest.
Make sure your joints are OK before replacing the boots.I recommend buying some CV joint grease ($4.95 valvoline )and put it into the boot using a grease gun.It will give you added protection.Do this once in 3 days so that you can keep the dirt out.
My 0.02
Take care ,
Jay
Are you sure I can?
Are you sure I can?
http://forums.maxima.org/showthread....highlight=axle
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
