popping sound when clutch engages
last couple weeks ive had some weird noises. when im taking off, maybe a milisecond after the clutch engages i get a popping sort of noise coming from the drivers wheel, or right in front of me im not sure, i just know its directly in front of me. i didnt relate it to the clutch until i was in my driveway and would let it engage with no gas at all and at the catch point everytime, it would give me the popping noise when it engages and a couple seconds after while the wheels were rolling. its not a pritty noise and its def worrying me, anyone? thanks
Transmission?
CV Joints?
Pressure Plate?
Throwout Bearing? - Naa that would only make noise while your disengauged.
Pilot Bearing?
Slave Cylinder?
Just a few items to think about.
CV Joints?
Pressure Plate?
Pilot Bearing?
Slave Cylinder?
Originally posted by QikEnuf
does it just pop once or does it do it several times, if it does it several times then you probably have the infamous clutch chatter
Originally posted by NotNew!!NewSN!!
pop a couple times, but its not like the car shakes or chatters or anything, u just hear them, and somewhat feel them under ur foot, but no actual chatter, more just hear them. i think when i let my friend take it out he destroyed it and clutch is on its last life, its not slippin at all though, just catchin rilly soft and makin those noises
hmm...you could do the 5th gear test to see if it slips, how old is the clutch???
70k miles on it, picked up car at 46k and felt little bit more wear then usual on it cuz it was a city only driven car(more wear and tear). its been through autocross and recently i think my friend scorched it, thats when noises begin. what is 5th gear test, dont tell me i take off in 5th gear
The fifth gear test is putting the car in 5th gear while at about 40-45mph to keep the engine revs low. Then, when you're in gear, floor the gas. If the engine revs but doesn't pick up speed, the clutch is slipping enough to where you should replace it. However, you already said it's not slipping so I dunno if this applies, but give it a try anyway and see what happens.
passes 5th gear test fine, and it def doesnt slip, just doesnt have bite, i duno, i want to do act clutch, but not if it isnt done, but if the poppin is cuz of clutch i will, i just dont want to change the clutch to find out its somewhere else.
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
