checking iac valve
Old Jul 6, 2002 | 06:42 AM
RI-Max's Avatar
checking iac valve (again) did ohms test
i just did the test i got about 30 ohms from 1,2-2,3-3,4-5,6 (all about 30 ohms) but i got 60 ohms on 3,4 ??? this means its a bad iac valve
ps: i had a high idle sometimes
change fuel filter
clean TB
new filter
Old Jul 6, 2002 | 11:57 PM
RI-Max's Avatar
bump!!
Old Jul 7, 2002 | 06:04 AM
njmaxseltd's Avatar
Clean the IAC valve.
Your test results were fine.
It sort of comes apart and then you can use throttle body cleaner in it to clean things up. That should make it stop hanging up, which is probably causing your high idle.
Also check and make sure your throttle cable isn't binding on anything and has just a slight bit of play.
Old Jul 7, 2002 | 10:00 AM
RI-Max's Avatar
and i cleaned my iac valve too and the cable looks fine wtf is it then grr
BkGreen97
Apr 2, 2016 05:47 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
