Axle & ABS problem
Old Jul 8, 2002 | 03:46 PM
vmarques82's Avatar
Axle & ABS problem
I just had my front axles replaced in my 91 SE and now when i hit 5MPH the ABS light comes on. Has anyone run into this before?
Old Jul 8, 2002 | 07:42 PM
mtcookson's Avatar
probably the abs wheel sensor but i'm not sure cause i've never heard of that.
Old Jul 8, 2002 | 11:27 PM
Evil Yak's Avatar
who did the driveaxles?
they may have broken an ABS wire or something
i did that before, boy i feel stupid
Old Jul 9, 2002 | 07:37 AM
keener's Avatar
To determine what the problem is, go into the trunk and under the rear deck the ABS computer should be flashing a red LED. Count the number of flashes. THis has to be done after you drive the car for at least one mile. ALso, the car must be running when the LED is inspected. DOuble check to make sure you don't have multiple codes and then get back to me with the number of flashes and I will tell you what is causing your ABS light to come on.
Old Jul 9, 2002 | 08:30 AM
vmarques82's Avatar
shop says
My guy at the shop says the axle has 2 more teeth on the gear than it is supposed to have. Supposedely it is supposed to have 44 teeth on the gear but instead it has 46. Has anyone heard of this being the case? Does anyone know if the 92-94 has more teeth maybe?
Old Jul 9, 2002 | 11:20 AM
AC439's Avatar
same thing...
Well, I replaced my left inner CV boot a month ago and I broke my left front ABS sensor. I don't know how I broke it but when I measure the resistance, it is open circuit. I think the sensor is very fragile so the bang and boom during the axle work might have broken my sensor. I have yet to find a replacement sensor from junk yard. Car-Parts.com doesn't seem to list it.
Old Jul 10, 2002 | 07:32 AM
keener's Avatar
Re: same thing...
let me know what sensor you need and when I get around to it i'll grab one from a yard here in St. Paul. Two weeks ago I picked up a right rear for $5.00.
Old Jul 10, 2002 | 03:23 PM
AC439's Avatar
Re: Re: same thing...
Thanks for your offer to help. Mine is a 92SE Auto. The ABS sensor I need is the one for the left-front wheel. I have the OEM part number written down and I'll post it here tomorrow. Let me know when you are going and how I can mail you a check. Regards. - AC
Old Jul 11, 2002 | 07:23 AM
AC439's Avatar
To Keener...
Hi Keener,
My left front ABS sensor part # as read from the part itself is -
47911-86E00
I have also sent this information to your private mail box in the board.
Regards,
-AC
Mar 12, 2020 12:06 AM
bbsitum
Sep 6, 2019 07:31 PM
boomerbrian
Oct 31, 2018 10:25 AM
wingnut2006
Sep 19, 2015 06:13 AM
maximusrising
Sep 2, 2015 09:55 AM
