side molding are off, now how do i get the shine back?
Old Jul 8, 2002 | 06:30 PM
nstymax93's Avatar
I finally got the side molding off and the sticky 2 sided tape! The spots where the tape was is faded pretty bad, how do i get that to shine back up? Ive already washed it! Now what?
-mike
Old Jul 8, 2002 | 07:23 PM
Mike S.'s Avatar
Whatever you do.....DON'T wax it. The molding is not only faded, but very dry. It will suck up wax like a sponge....and dry white. The only way to get the sine back is to paint it. Find your color at www.paintscratch.com Get the spray with the "flex agent".
Mike S.
Old Jul 8, 2002 | 07:36 PM
maxdout92se's Avatar
aww man...that was tha first thing i did after i removed the molding...didn't turn white, but i didn't get all tha adhesive off either!!
Old Jul 8, 2002 | 09:56 PM
D-sta's Avatar
just paint it
Old Jul 9, 2002 | 07:05 AM
nstymax93's Avatar
I am getting it painted and shaved, but i just want to make it look better for the time being!!
Old Jul 10, 2002 | 09:30 AM
92 Max's Avatar
weathered side molding removal
I'm replacing my sidemolding right now. New ones already painted in the body color are still available from Nissan, much to my surprise. I got help from a body shop who said to use a heat gun (or hair dryer) to soften the adhesive and remove the side moldings, using a plastic spatula or scraper to remove the moldings. They then use a rubber eraser style wheel on an air grinder type tool (spins it) to "erase" off the rest of the stickum. I suppose you could also use 3M adhesive remover. That stuff takes off any adhesive. Once its clean and cleaned of wax, the new moldings already have the sticky tape on them. Just peal the backing off and stick on.
Good Luck
Old Jul 10, 2002 | 09:37 AM
nstymax93's Avatar
thanks but im not putting new moldings on......and ive already got the tape off, i used sticker shock and it desolves the tape and i used the top of from the can to get the sticker off! Im hopefully getting the door moldings shaved next month. Thanks anyways
Old Jul 10, 2002 | 12:07 PM
matt1sd's Avatar
Re: weathered side molding removal
Good Luck
how much were new moldings?
Old Jul 10, 2002 | 01:18 PM
92 Max's Avatar
Re: Re: weathered side molding removal
About $80 for a front molding and $60 for the rear.
JRod28
Dec 29, 2023 09:56 PM
fastcarny
May 18, 2020 10:40 AM
boomerbrian
Nov 8, 2015 05:10 PM
shaunkey1
Aug 18, 2015 10:09 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
