Please Read before posting: Nitrous FAQ's
Old Nov 19, 2002 | 08:21 AM
mtrai760's Avatar
'Trynna' is not a word
Nitrous FAQ's
I'll start by posting links to a few threads that are very helpful along with credit for each... and it's Nitrous not NOS or nawz...
Article by: mtrai760
Article by: Jime
Article by: sx7r
Article by: Mardigrasmax
Please feel free to add USEFUL information, and post questions elsewhere. We can get a FAQ started here. No PW's please, thank you.
Old Nov 19, 2002 | 12:59 PM
SmoothMax's Avatar
OG
Here's a short explination on how Nitrous works courtesty of howstuffworks.com
Old Nov 19, 2002 | 07:47 PM
mtrai760's Avatar
Q: Which nitrous kit can I use, and which is the best?
A: It's really up to you. Nitrous express, Zex, and NOS all make kits that have proven reliable on many members cars. Some prefer one over the other, but they are all good kits.
Old Nov 20, 2002 | 07:16 AM
Sprint's Avatar
Installation Instructions for NOS Kit #5124
http://64.252.156.63/nos/Matt_NOS_Instructions.pdf
NB: Please Right Click and Save.. Viewing the PDF will bog down my server
*** Adobe Acrobat Reader Download ***
its a free download and is required to view this installation instruction file
Old Nov 20, 2002 | 11:01 AM
SmoothMax's Avatar
OG
Basic "Dry" setup
Old Nov 20, 2002 | 11:03 AM
SmoothMax's Avatar
OG
Basic "wet" setup
Old Mar 28, 2003 | 09:28 AM
jmartinson's Avatar
DIY Nitrous for Budget minded folks
build your own hardware kit:
http://nitrous.info
build your own multistage controller:
http://www.kwantlen.bc.ca/electech/F...al-Project.pdf
Old Jun 5, 2003 | 01:10 PM
xHypex's Avatar
Nitrous Information from NissanPerformanceMag.com - June 2003
http://www.nissanperformancemag.com/june03/ask_sarah/
The article is pretty thorough, and seems to take the conservative approach (as if that's a bad thing).
-hype
Old Jul 20, 2003 | 08:36 PM
Pinnacle's Avatar
i see ther is no link under SmoothMax's "wet" or "dry" setups.. That is exactly my question - what is the difference?
Old Aug 12, 2003 | 07:34 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Dont you see how the nozzles are different in the setups?
In a wet kit, the fuel and nitrous mix together 50/50 in a nozzle then enters the throttle body premixed for best results. No tuning necessary.
The dry kit has only a nitrous line connected to that nozzle. Letting nitrous in to the throttle body and bumping up the fuel pressure and the injectors supply the fuel for the nitrous and mixes in the combustion chamber.
Obviously, the wet kit will mix better.
Old Aug 12, 2003 | 09:13 AM
xHypex's Avatar
I have no problems with wet kits, and if I hadn't considered using nitrous with forced induction I would have a wet kit. That said, could you be any more biased in your posts I agree that a wet kit will probably have slightly (depending on the shot) better distribution to the individual cylinders, but I don't agree that it will be mixed better by the time it hits the cylinder. If it was that beneficial to introduce fuel with the nitrous in the intake path then no one would want a direct port setup expecially NX's NXL setup.
Go with whatever setup suits you best, but be sure to take a look at the whole picture before you purchase.
-hype
Old Aug 12, 2003 | 08:02 PM
Eat Naaawwwzzzzz
I agree with you my post is strongly biased, but for an obvious reason. Sure you can get a good mixture with a NOS system, but how much tuning will it take you to achieve that? I just belive a premixed shot is much better then letting it mix in the cumbustion chamber.
The best way to distribute nitrous evenly is obviously a DP setup. But the lowest shot is a 150 for dp.
Old Dec 23, 2003 | 01:58 PM
Beemen550's Avatar
deletedddddd
Old Apr 18, 2004 | 01:16 PM
Jime's Avatar
Jet Sizes for NX, Zex and NOS
Old May 18, 2004 | 09:20 PM
baughb's Avatar
Dry
Wet
'Direct Port'
Old Apr 17, 2005 | 09:37 PM
CyMax's Avatar
Ok sooooooo let's look at this in terms of engine safety over the long haul. If I have set up blank and use it once in a while for say 4 or 5 years, what are the chances, per system that I will send a totally fork my engine?
Old Apr 18, 2005 | 09:24 AM
mtrai760's Avatar
Any system with proper tuning and maintenance (for both the car and the nitrous system) should last many many years. This is assuming of course that your engine is in proper condition, that you use the proper safety devices, etc etc. It's all going to depend on you, there is no definitive answer.
Old Nov 19, 2005 | 04:04 PM
KRRZ350's Avatar
Zex makes an electronic tps sensing switch that works with our dropping voltage tps. Simply wire it in, push a button, watch the lights, floor the car, watch the lights again, and the voltage curve is learned, no more ghetto wot micro-switch!
Old Dec 20, 2005 | 01:07 PM
2002AltimateV6's Avatar
Automatic Transmission + NITROUS
It seems during all my searches I haven't really found anything that answered questions on wether it's safe or not to spray during when the transmission was shifting? Basically like, once the tree falls and hits green and you're off, would it be safe (at WOT, of course) to keep the "button" pressed and have the nitrous sprayed through-out the entire 12-13 seconds during your race, through every shift?
Also- I've read a bit up ont he concept of "nitrous backfire." I know this is caused either when nitrous is pooled up in the intake/manifold and spark hits it and BOOM, or when too much nitrous/fuel is injected without the required amount of air (below 1,000RPM's) but what about everyone that uses nitrous from off the line? How are they immune to this concept? Or is this "nitrous backfire" all a matter of wether or not you're at WOT?
Old Dec 20, 2005 | 01:32 PM
mtrai760's Avatar
On both a manual and auto setup you have a WOT switch, or wide open throttle, that only allows nitrous to spray when the throttle is all the way open. What that means is on a manual, unless you are trying to destroy your transmission by power shifting, you will not be spraying between shifts. On an automatic, it is okay to spray between shifts, however I recommend you have a window switch, just in case your transmission fails, you won't also take out the motor. The window switch is recommended for the manual as well.
On nitrous backfires, it can happen at any time. The best thing to do is to have a wideband A/F meter to show if you are running to rich or lean. Many of them can be setup to shut off your nitrous if you exceed certain perameters. Its usually not a matter of too much of both pooling, but of the fuel pooling. This is primarily an issue with wet kits, however if you keep everything setup and running properly, as well as have the requisite A/F gauge (wideband, not the autometer light show) You should be fine.
Old Dec 28, 2007 | 04:12 PM
gunzs's Avatar
well that answer half my qustion i have a zex 75 horse kit ,my problem is that my system feels like it spools up like turbo ? is that how it suppoed to feel? is that maybe the pooling you guys are saying?this is my first nitros kit, i also had a company install it so not to sure on all. i have tooken it back couple time and they all say its cool but i just dont feel like its at potential. my buddy got 5th gen too but he uses 100 shot and diffent system but seems like his so much powefull .if someone could school me more i it would be great,i have read threads but need it broken down better for me thanks guys
Old Dec 28, 2007 | 11:11 PM
Do you have a purge? That gradual feeling could be air/stale nitrous left in the line that has to be pushed through before it gets the fresh nitrous into the intake. But that's only if you don't have a purge. And trust me, a 100 shot is a NIGHT & DAY difference compared to a 75 shot. Sure it's only 25 more HP, but man oh man.. it hits so much harder.
Old Jan 1, 2008 | 07:31 AM
gunzs's Avatar
first off thanks for helping me out, yea have purge kit. yea i do hit the purge buuton before i go looks great comming out from the hood!! i put 100 jets in same feeling even went up to 125 (unbelievable) power there but still feels like its spooling up like turbo, my buddy says that maybe they didit that way to be safe on moter? does that sound right? i have a venom engine mangement onboard computer but the people lock me out of the nos screen so i cant make any fine adjustments with the nos iwas running 14.5 before nitos upgrade what do u thin i should be running with that? thank for helping me out taking away your time gabe aka gunzs... SHIFT_ tiket
Old Jan 21, 2008 | 03:57 PM
Grand_hustle17's Avatar
i've got a 5th gen auto, and im looking at a dyno tuned wet kit, now im a nitrous noob, but i was thinking of a 100 shot... my question is instead of a safc, can i use a greddy e-manage, and is there anything i need to change with a 100 shot??? i am already changing injectors, anything else? thanks... oh and also with any kit, does it also comes with everything ready for installation?
Old Feb 18, 2008 | 10:50 PM
happy4444's Avatar
bump for answer
Old Feb 24, 2008 | 09:27 AM
SLPMAXDuP's Avatar
" And trust me, a 100 shot is a NIGHT & DAY difference compared to a 75 shot. Sure it's only 25 more HP, but man oh man.. it hits so much harder."
Are NOS shots measured by HP? I've never looked into them, but I always figured it was volume
Old Jun 29, 2008 | 10:37 AM
MoncefA33's Avatar
I am looking at running between 60-75 shot nitrous (dry), and had a few questions regarding my 01 Maxima handling it.
The car is a 5 speed, and has about 107k on it, which is quite a bit, but the car has been well taken care of, maintenance wise.
I am interested in the ZEX dry kit, and am wondering, does the "Nitrous Management Unit" have an FPR inside it, to bump up fuel pressure? And will my stock injectors be able to support upto 75hp jetting?
Also, how would other internal components be able to support that much nitrous? And would I need a wideband O2 and something to tune with, or would that purple box be able to handle fuel enrichment adequately?
Old Feb 17, 2009 | 09:15 AM
07whitey's Avatar
you kno it kinda weird actually i have been wantin to make a post on this i jus got my nitrous installed(75 shot zex on a 07) and it shot in maybe a boost leak and blew out my egr valve(power valve) and destroyed my throttle body and threw two codes one being and idle range and tps sensor and im getting a slip and tcs and brake also...omeone help me well actually us!
Old Feb 17, 2009 | 10:34 AM
streetzlegend's Avatar
That's called a nitrous backfire, it means fuel puddled at the intake runners and ignited causing an explosion inside your intake manifold, so the pressure goes out the easiest places like the TB and egr. This is not a good thing and your lucky you didnt blow the intake manifold through your hood or worse. maybe a fuel solenoid got stuck open, or too much fuel is being used as compared to the nitrous.
Old Feb 18, 2009 | 03:39 AM
07whitey's Avatar
so u think i should take it back to the place i got it installed and say her can u jus look over everythin make sure everythin is ok all the lines and stuff or what u think i shud do to prevent it again
Old Feb 18, 2009 | 09:24 AM
Yea, make sure they installed the proper size jets, and make sure the solenoids are fine and not stuck open like the fuel, just look over everything, its not normal to have a backfire, unless you hit the rev limiter, or sprayed it too early in RPM, try not spraying below 3k rpm. 1st gear maybe, since it rev's fast, but as a precaution
Old Feb 19, 2009 | 03:55 AM
07whitey's Avatar
ok cool cuz that weird cuz i ordered the jets myseld from zex and they give u the rite size jet for the shot want ill check it to see if they messed up and what solenoids like were r they located at?
Old Apr 10, 2009 | 03:59 PM
maxima415's Avatar
can i run a zex wet 75 shot without any other mods?
Old Aug 11, 2009 | 08:01 PM
jake8524's Avatar
I have a 97 se 5 speed.What would be the biggest shot (dry) i could put on it without any more upgrades?
Old Aug 11, 2009 | 09:54 PM
02specvq's Avatar
yea a lot of people run 75 shot wothout any upgrades...i wouldn't recommend going any bigger though...
Old Sep 16, 2010 | 10:49 AM
blackmaxftw's Avatar
Hwats the part number for the 2 step colder ngk plugs
Old Oct 25, 2010 | 09:54 PM
MaximaZsl's Avatar
Nitrous Help!
I have a 2004 6th gen I want to put a wet kit on I want some advice from people that have seen or owned a 6th gen on spray
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
