fuel pressure for 100shot
Old Dec 1, 2002 | 12:56 AM
irvine78's Avatar
well, i have a dry kit set up. can't seem to take full advantage of the 100shot tho. for those of you that already ran 100shot set-up and got good times, what was your fuel pressure set at? 85psi?
Old Dec 1, 2002 | 12:59 AM
mtrai760's Avatar
'Trynna' is not a word
Re: fuel pressure for 100shot
between 82-85psi for me, but I had a short sweep fpg, so I cant be 100%, but that was roughly it... what bottle pressure are you running Hoon?
Old Dec 1, 2002 | 03:10 PM
BC_95GLE's Avatar
Re: Re: fuel pressure for 100shot
Mine was 83 psi. Brian
Old Dec 3, 2002 | 12:15 AM
irvine78's Avatar
another Fuel quetion..
instead of getting a Walbro 255lph pump, i opted for a MSD in-line fuel pump instead. this MSD pump has a flow capacity of 166lph @ 40psi of fuel pressure.
what i'm curious about is that when Walbro says the fuel pump has 255lph flow capacity, at what pressure is that reached?
thanks in advanced.
Old Dec 3, 2002 | 12:38 AM
mtrai760's Avatar
fuel pressure Gal/min
0 84
10 82
20 78
30 73
40 68
50 64
60 59
70 55
80 46
90 38
100 19
more info here:
www.autoperformanceengineering.com
Old Dec 4, 2002 | 06:35 PM
Iron Lung's Avatar
Re: Re: Re: fuel pressure for 100shot
The only way to exactly know where you need to be is to use a wide band a/f meter at the dyno.
I run my system with no bypass jet, my pressure is @80psi and I'm still running very rich.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
