window switch/tranny question
Old Dec 18, 2002 | 12:35 PM
ChillWill2000's Avatar
Im planning on going w/ the nx kit w/ my 2k auto.
the question is if I get a window switch w/ the setup can a go a while longer w/ out a vb mod and tran cooler???
is that the point of a window switch, so it dosent spray when you shift right?
Old Dec 18, 2002 | 02:29 PM
Jime's Avatar
Re: window switch/tranny question
Trans cooler is cheap, dont run without it. VB Mod, personally I wouldn't have one but then I wouldn't have a window switch either.
Old Dec 18, 2002 | 07:59 PM
imported_2_tha_max's Avatar
Is it necessary?
Is the window switch necessary when using nitrous? I am using a nx kit but a friend has a zex kit. He says that I need to use a window switch. He purchased some computer controlled distribution option with his zex kit. I thought that a window switch is only neede if you have an autotragic. I rather spend money on a bottle opener.
Old Dec 19, 2002 | 06:54 AM
SLC I30t's Avatar
Does anyone know if you can use a MSD RPM activated switch?
Old Dec 19, 2002 | 08:32 AM
Aaron's Avatar
Langley AFB Sux
Yes you can use one. MSD will program it for our car for 40 bucks or something. I bought mine used from an org member. I have it set to engage at 3400 and disengage at 6000. I run the zex kit as well.
Old Dec 19, 2002 | 09:47 AM
Synki's Avatar
I never sprayed through gears - in between ****s that is.
You can use the MSD window switch but you will have to have it modified for 1 cylinder application.
Old Dec 19, 2002 | 04:51 PM
SLC I30t's Avatar
modified for 1 cyl?
Old Dec 19, 2002 | 08:16 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
interesting. why is that, because of the ignition system?? what can this cause if not re-propgrammed for "1 cylinder"?
Old Dec 19, 2002 | 09:26 PM
mtrai760's Avatar
'Trynna' is not a word
Yes, it's because of the ignition system. The MSD switch was originally designed to be used on vehicles with a distributor, that we don't have, so it must be modified to read off just one cylinder.
Old Dec 19, 2002 | 11:00 PM
DA-MAX's Avatar
cool, so if installed without the reprogramming are there any adverse affects or malfunctions??
Old Dec 20, 2002 | 07:24 AM
1MAX2NV's Avatar
It just doesn't work.
Old Dec 20, 2002 | 07:28 AM
DA-MAX's Avatar
thanks, cause I think we might have a problem with the window switch in my friends 2k2 Civic(since it has direct ignition)
Old Dec 20, 2002 | 07:31 AM
1MAX2NV's Avatar
The purpose of the window switch is really NOT saving your tranny. If you only want to spray while the tranny is not shifting, then you are only spraying from 4200RPM to 6200RPM. You won't get as much performace as you can. I like to spray my nitrous from 3200RPM in 1st gear and leave it on through out the rest of the gears. The purpose of window switch is so that you don't spray nitrous below 2500RPM and not above 65000rpm. Above 6500rpm, you will hit a fuel cut. That's really bad if you are running a dry kit and hitting the fuel cut. NOS recommend you don't use nitrous below 2500RPM because you are probably not at WOT at that point.
Old Dec 20, 2002 | 08:31 AM
SLC I30t's Avatar
Tony- Where do I send my MSD to get it "reprogrammed"?
Old Dec 20, 2002 | 08:56 AM
1MAX2NV's Avatar
Go to their website and the address should be under their Tech support section. Put the switch inside the box and put a note says "Modify it for 1 cylinder application for 19XX Nissan Maxima with distributorless ignition system". I think it's like $40 to do so. I don't remember how I paid for it. I think I just included a personal check.
Old Dec 20, 2002 | 10:19 AM
Synki's Avatar
There is no distributor and the maxima uses individual coil packs.
It costed $30 for the mod I think. It has been so long.
You need to send the MSD switch to MSD. hehe.
pears
Sep 18, 2015 05:25 AM
