nitrous how big of a shot?
Old Feb 6, 2003 | 09:41 PM
slammed97SE's Avatar
I have a 97 Se maxima. I have a cai, and a hi-flow cat and
cat back exhaust. I was thinking of putting a n.o.s dry kit on
my car. I was wondering what big of a safe shot I could go with?
and where should I put the nozzle at? before the mass air or after?
thanks
Old Feb 6, 2003 | 09:48 PM
Ramius83
The nozzle for the nitrous kit will go AFTER the MAF sensor.
On the stock fuel pump, you can run safely up to a 70 shot. If you got a Walbro 255lph fuel pump, you can run any shot indefinitely, just depending on your engine work. But on a dry setup, you do not want to go over a 100 shot.
The nozzle itself will go in the upper intake "piping" where those two/three vacuum hoses tap into.
Old Feb 6, 2003 | 10:02 PM
thanks, should i put a y-pipe on it also? I am kinda new to
the maxima scene. and where could I get one at? thanks
Old Feb 6, 2003 | 10:06 PM
Is there anything I need to do to the car
before I try to spray it?
Old Feb 6, 2003 | 10:20 PM
96_vqmax's Avatar
Definately,you can get it from buget($160.00) or warp speed performance($240.00).Mine is wsp. You can do a search there are tons of thread about y pipe.
Old Feb 6, 2003 | 11:19 PM
JAIMECBR900's Avatar
You really should post this question in the nitrous forum. You will likely get more responses there.
Old Feb 7, 2003 | 10:09 AM
mtrai760's Avatar
'Trynna' is not a word
Read the FAQ's
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
