N.O.S. users please help me again.
Old Feb 19, 2003 | 06:50 AM
SLC I30t's Avatar
What size Bypass jet do you recommend for a 70 shot NOS n2o system?
I have the stock .042? bypass jet and I'm getting about 80-90FPSI. So basically I'm way way too rich. Do I go up in size to lower the PSI? I want to be around 60psi from what I remember reading. I have a SARD FPR and Walbro255lph pump.
Old Feb 19, 2003 | 07:26 AM
Jime's Avatar
Re: N.O.S. users please help me again.
You have to go smaller. I would try in the 34-36 range but its trial and error to get it precise.
Old Feb 19, 2003 | 07:41 AM
mtrai760's Avatar
'Trynna' is not a word
Actually with NOS, you probably need to go bigger. I was running a .055 bypass with a .042 jet, but it's really going to depend on your car. You also want to keep the fuel pressure a little higher than that, you should be around 70psi+ with a 70 shot. I tried going with a smaller jet, down to a .032, and my fuel pressure didn't get any lower, it wasn't until I tried a bigger jet that I got my fuel pressure to go down, and this was using the 255lph fuel pump. Good luck.
Old Feb 19, 2003 | 07:50 AM
Jime's Avatar
You are right, I was looking at the wrong column in my chart. Sorry SLCI30t.
Old Feb 19, 2003 | 10:03 AM
SLC I30t's Avatar
I know that we've used the 70 psi with our cars to match the EGT temps with typical driving. After doing a dyno I noticed our cars run very rich, thats why I was going to try to pull the PSI down to try to lean the car out a little.
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
JonBlz
Oct 5, 2015 06:02 PM
