spark plug info for 2k2 on NX
Old Mar 13, 2003 | 04:57 PM
elchino's Avatar
I was planning on going with NGK coppers for my 2k2. Anyone know item numbers and such?
Old Mar 15, 2003 | 06:43 PM
Donkey®'s Avatar
wat
PLFR6A-11 (Platinum 1 step colder)
LFR6A-11 (1 Step colder Copper)
Old Mar 19, 2003 | 06:31 PM
elchino's Avatar
You da man! How much of a P.I.T.A. is it to change the plugs in the back? Looks like we have to take off the intake manifold on '02s and '03s.
Old Mar 25, 2003 | 04:41 PM
HitManSE's Avatar
Real big PITA, I belive the intake manifold must be removed.
Old Mar 29, 2003 | 09:24 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
DUDE!
OMFG!
I changed them last week to NGKs bkr6g-II one step colder gapped to .36
You dont know how much of a PITFA it is to do!
THe fronts are simply.Typical.
The rears! Oh Man! THe middle ignition coil must come out and the throllle body is in the way. Must take it off.. 6 screws total 2 on top,2 on bottom and 2 to the side(right).
To get the the rear left ignition coil you must remove the intake manifold becuase the dam bolt wont come off. Needs only about 1/2" more! Dam japs! 5 screws for that. Just needs to be lifted about an inch, not totally taken off. I took if off cuz it was kinda cool in there
Strut bar MUST come off..if you have one.
Those 1 foot extention ratchet things are a must. 6" + 3" is ok.
Oh and, you LOVE this one!!!
The spark plug socket doesnt fit inside the chamber where the spark plug is! GRRRR
Japs are dumb!
Dont forget to put ALL the hoses back on and reconnect everything!
Good luck
Old Mar 29, 2003 | 09:35 PM
elchino's Avatar
That's what I figured.
Old Apr 20, 2003 | 03:05 PM
SR20DEN's Avatar
VQ Wizard
It's not a big deal. The manifold comes off pretty easy. The entire job can be done in half an hour.
If you want to see a ***** try changing plugs on a Subaru boxer.
Old Apr 20, 2003 | 06:54 PM
Eat Naaawwwzzzzz
its really not, just a PITA,
on my old eclipse. theyre all right in front of ur face!
Old Apr 20, 2003 | 06:58 PM
SR20DEN's Avatar
VQ Wizard
The SR20DE was about the easiest of any. I was just saying it could be alot worse. (LS1, WRX, GM 3.4DOHC X motor just to name a few)
Old Apr 20, 2003 | 07:29 PM
HitManSE's Avatar
The LS1's are definetly a fine example of a PITA spark plug job. Minivans blow too.
Old May 2, 2003 | 08:23 PM
elchino's Avatar
Just noticed (kinda off-topic): everyone on this thread so far is a donating member. Good job!
Old May 6, 2003 | 10:19 PM
Eat Naaawwwzzzzz
Old May 7, 2003 | 12:18 AM
HitManSE's Avatar
You just wanted to bump the thread didnt you.
Old May 7, 2003 | 05:11 AM
SonicDust187's Avatar
Same. It was PITA to change the back plugs on my 4th Gen.
Old May 7, 2003 | 05:50 AM
Blu's Avatar
Blu
the tits
Old May 7, 2003 | 03:45 PM
zeff789's Avatar
Not anymore, ahhahahaha!
Old May 7, 2003 | 03:55 PM
HitManSE's Avatar
Uhhh, why is it a PITA to change 4th gen plugs? The plugs are right there, takes me no more then 30min to R&R them all. It is a must to have the right tools though, otherwise it is a PITA.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
