NEEDED: Pics of Fuel T splice location
Old May 6, 2003 | 07:13 PM
TylerBorg's Avatar
I am going to buy the NX 20923 most likely.
The only part I am worried about is tapping into the fuel system.
I heard that I need a bigger T for this.
Can someone who has done this comment on the bigger T issue and post a picture of the place where you integrated it. Thanks.
Tyler
Old May 6, 2003 | 10:11 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
You can find info on the Tee you need here.
Jim...'Jime' talks about it and he's me nitrous around here..imo..
as for the tee I got pics but I got a 2002.you should PM Jime for pics or hit me up on AIM and IM me, ill send you the ones I have...
EDIT: heres the link.. lol
http://forums.maxima.org/showthread....hreadid=210622
Old May 8, 2003 | 07:15 AM
XXXL Cracker's Avatar
I will post some pics tonight.
You will needs some 5/16 fuel line hose.. Make sure it is fuel line hose. You will also need some fuel line clamps.
I attached an 18" piece of the new hose to the top of the filter, clamped it. I then attached the hose in this order to my tees:
HOSE ----> 5/16" barb--->1/8" tee----> 1/8" male to male connector ----> 1/8" tee----> !/8" male to male connector----> 1/8" tee------> 5/16" barb which was connected and clamped to the stock fuel line which runs into the engine.
I chose to keep the stock fuel line in case I ever need to remove the kit and return to stock.
Make sure you get fuel line clamps
Make sure you use fuel line hose.
Use a teflon based sealer on all threads. You do not want a fuel leak for obvious reasons.
The Nitrous kit comes with it's own selaer for all threads. Do not use the Nitrous sealer on flare fittings...Big NO NO!
I will post some pics tonight!
D
Old May 8, 2003 | 02:53 PM
xHypex's Avatar
Definitely use a vise to tighten your fuel fittings. Being in a dorm I didn't have a vise available, so I think I'm going to have to remove mine and retighten when I get home
-hype
Old May 8, 2003 | 06:42 PM
TylerBorg's Avatar
jime... thx for the response... im going to need some pics as i dont know which line to tap into..
also can the fuel line run from the trunk, threw the hole in spare tire well, under the chassis, all the way to the engine? it seems like longer then 16ft
Old May 8, 2003 | 11:50 PM
Eat Naaawwwzzzzz
Here you go, this is for a 2k2
http://www.boostedmaxima.com/images/...p/100_2652.jpg
http://www.boostedmaxima.com/images/...p/100_2653.jpg
http://www.boostedmaxima.com/images/...p/100_2654.jpg
http://www.boostedmaxima.com/images/...p/100_2662.jpg
http://www.boostedmaxima.com/images/...p/100_2664.jpg
http://www.boostedmaxima.com/images/...p/100_2665.jpg
http://www.boostedmaxima.com/images/...p/100_2667.jpg
http://www.boostedmaxima.com/images/...p/100_2668.jpg
http://www.boostedmaxima.com/images/...p/100_2669.jpg
Enjoy =]
They're all pretty bug 1/2 meg to a meg in size. So if you got Dial up..sorry lol
2160 x 1440 pixels...
Old May 8, 2003 | 11:54 PM
Eat Naaawwwzzzzz
DO you know the strategy to remove te fuel pressure?
fuse..starting...yada yada?
Dont cut into the line without doing that...
Let me know if you dont know it..
Old May 9, 2003 | 07:45 AM
Pretty important point.....
Old May 9, 2003 | 09:09 AM
1BaDMaXiMa's Avatar
Can i do this to my 03.....im so confused, some tell me no and some tell me yes...
LEO
Old May 10, 2003 | 03:33 AM
Eat Naaawwwzzzzz
do what?
Old May 10, 2003 | 10:19 AM
TylerBorg's Avatar
ooo ive got a 96.... anybody?
Old May 10, 2003 | 10:31 AM
SonicDust187's Avatar
Where did you get the 5/16 fuel line hose? So now I have to go and get 6 fuel clamps, those tees and fuel line hose. Dam.
Old May 10, 2003 | 10:34 AM
TylerBorg's Avatar
also if you could post how to remove the pressure that would be good too
Old May 11, 2003 | 04:49 PM
zeff789's Avatar
I also need to know this.. It would be VERY VERY helpful if we could get some pics of where we are supposed to tap the fuel line for a 95/96. I've checked the pics and have only seen the general location for this. Any help, please?
Thanks,
Jeff
Old May 11, 2003 | 04:55 PM
zeff789's Avatar
Thanks,
Jeff
Old May 11, 2003 | 06:32 PM
Eat Naaawwwzzzzz
Turn the car off...take out the fuel pump fuse
start the car, let it die...
do this like 8 times or so until you feel thers not much pressure left..
Unscrew the little football like connector (cant think of the name right now)
Get a towel, wrap around it and pull. The excess fuel will get on the towel, not all over your engine
And Merry christmas
Old May 11, 2003 | 06:41 PM
Thanks,
Jeff
All - I put some pictues on my Homepage. I got an extra piece of 5/16" fuel line. I connected this to the top outlet of the fuel filter and connected my tees to it. I connected the other end of the tees to the pice of stock fuel line that I removed from the top outlet of the filter.
This will complete your fuel line tap. I have a pirture of the top of the outlet on my homepage.
It is pretty straight forward and does not require any cutting etc. Whe I am ready to return to stock, I can just remove the tees and the extra line and connect the stock line again.
This was done a 1997. I am not familiar with the 5th gen's.
D
Go to : http://forums.maxima.org/showthread....hreadid=213936
Old May 11, 2003 | 08:26 PM
TylerBorg's Avatar
is the fuel pump fuse in the engine bay holders?
Old May 11, 2003 | 08:39 PM
Eat Naaawwwzzzzz
in the drivers compartment fuse box
Old May 13, 2003 | 03:29 PM
Fuse box to the left of the steering wheel. Pull off the cover, all of the fuses are labeled.
You will have to work a little bit to remove the hose which connects to the top of the fuel filter.
D
Old May 13, 2003 | 08:41 PM
TylerBorg's Avatar
Found it all... I'll let you know when I get the install started... Thx guys!!! so I need 5/16 hose clamps right? the good ones obviously
Old May 14, 2003 | 05:33 AM
Ok guys, I am about to go and buy two 1/8"NPTx5/16" Hose Bard, one 1/8" NPT Tee, one 1/8" NPT x 1/8"NPT nipple, six fuel clamps (what size?), and one 5/16" fuel line(how long?).
Old May 14, 2003 | 05:36 AM
I used an 18" piece. It allowed me to have more freedom with the tee mounting location.
d
Old May 14, 2003 | 05:51 AM
What about the fuel clamps what size?
Old May 14, 2003 | 07:13 AM
xHypex's Avatar
If the hose is 5/16"s and the barbs are 5/16", then you probably want 5/16" fuel injection hose clamps
Also be sure to put a generous amount of paste on the threads and tighten in a vise. My tees were leaking, so I had to pull them again yesterday and repaste/retighten.
-hype
9aj9
Apr 5, 2020 12:11 AM
aminus21
Sep 12, 2015 04:53 PM
