Do I have to change plugs?
Old Jul 18, 2003 | 09:07 AM
Bluebird's Avatar
I am Roid Rage
I'm contemplating picking up a NX wet kit and I only want to run a 50 shot. I'll probably only use it 10-12 times a month and I drive about 1800 miles a month so I don't want to sacrifice NA performance by going to colder/copper plugs. So, do I have to change those plugs?
Old Jul 18, 2003 | 01:05 PM
Jime's Avatar
Re: Do I have to change plugs?
I would recommend at least 1 step colder ie BK6ES. Mine has BK7ES plugs in all the time (2 steps colder) and I still run a 14.6 N/A with an automatic so its not really a performance sacrifice.
The only time I notice anything is when the car is cold and then it stumbles for a second or two until it gets out of the driveway, after that its fine.
Old Jul 19, 2003 | 09:12 AM
xHypex's Avatar
Re: Re: Do I have to change plugs?
Is your 14.6 on slicks? If it is then I don't feel so bad. I just dynoed (waiting for my post in the dyno slip to be approved) and I feel like I lost a lot of power. One of the only major changes was changing to 1 step colder plugs.
-hype
Old Jul 19, 2003 | 06:03 PM
Jime's Avatar
Re: Re: Re: Do I have to change plugs?
-hype
Hype I don't run anything but slicks unless I am messing around, street tires are really useless, especially when you get down into the 13's and below. 14's and 15's not too bad with good quality street tires but they are too expensive for me.
Old Jul 20, 2003 | 06:59 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
street tires suck
Old Jul 21, 2003 | 09:49 AM
Bluebird's Avatar
I am Roid Rage
Jime,
thanks for the reply. One more ?, what exactly is the reason for the colder plugs? Is it to prevent engine damage or is it for beeter on-the-bottle performance?
Old Jul 21, 2003 | 10:02 AM
Jime's Avatar
Jime,
Engine damage. Same for copper vs platinum. Copper has a more consistent spark. Ditto for closing the gap some too, its to prevent the higher pressure in the cyl from blowing out the flame as easily. I run my plugs at .035 vs .044 stock. For smaller shots .040 and 1 step colder is probably optimum.
Old Jul 21, 2003 | 12:33 PM
xHypex's Avatar
From the 5th gen FAQ:
Originally posted by y2kse
Spark plugs have two jobs. 1) To produce a very high temperature spark to ignite the air/fuel mixture as quickly as possible. 2) To fine tune the temperature of the combustion chamber. Number 2 is the "heat range" of the plug.
Most plugs do this just fine, with each manufacturer being a little different in their specifications (i.e. a heat range of "5" in an NGK is not the same as a "5" in a Bosch). There are equivalency tables, but don't expect them to be too accurate.
So I'll just concern myself with Number 1. To create a spark, we must produce so much voltage across the air gap that the air becomes ionized (the molecules split apart and the electrons fly *****-nilly). This creates very intense heat, hopefully plenty to ignite the compressed air/fuel mixture, and the plug has done it's job (#1).
The shape of the plug electrode is important. The sharper the electrodes (both of them!) become, the easier it is to ionize the air between them. If I take two smooth brass ***** of 3" diameter and put 10,000 Volts across them, I can get a spark to jump when I push them to within about 0.125" of each other. If I take two long, sharp needles pointed at each other, that same 10,000 Volts will still spark when they are 1.5" apart! (For the technically minded: this can easily be seen from Gauss' law if you compare E between the extremes of either two point charges or two equally spaced infinite parallel planes).
There is also another good reason for sharp points: "unshrouding" the spark. Imagine that we put a big flat plate over the tip of the ground electrode, thus shrouding the spark from the combustion chamber. The spark would still happen, and the mixture would probably still ignite, but the burn would have to go out, around the plate, and back in to the center of the combustion chamber, resulting in piston rock and detonation. We'd much prefer that the burn happen in a very smooth, ideally hemispherical manner to produce a smooth pressure curve inside that chamber. By keeping the electrodes sharp, we unshroud the spark as much as possible, allowing the maximum contact between the spark and the air/fuel mixture, making it ignite more easily and the burn spread more smoothly.
So it would seem that the sharper the electrodes, the better. This would be true except for two caveats having to do with heat. The very hot spark emanates from the electrodes at their tip. If this tip is very sharp, it will get extremely hot because there is so little metal to heat and there is not enough area to conduct that heat away. Think of it this way - if you unbend a paperclip and hold it's tip in a blowtorch, the tip will glow red hot in seconds, but you'll still be able to hold the relatively cool end. Now take a short piece of rebar and do the same thing. Long before the rebar gets red hot, you will have dropped it and will be sucking your thumb to quell the big, burned blister that is popping up. Why? Because the rebar had lots of metal volume to heat and plenty of area to conduct that heat to your hand, whereas the paperclip had neither. So the paperclip end got much much hotter in much less time. The paperclip is like a sharp tip and the rebar is like a fat tip (if you didn't get that already).
So, the caveats:
Caveat number one: Too sharp a tip will melt the electrode. If the temperature of the tip reaches the melting point of the metal that it's made of - you can kiss it goodbye. Here are the melting points of some commonly used metals (Celsius):
Zinc == 420
Aluminum == 660
Copper == 1083
Steel == 1400-1500
Platinum == 1772
Iridium == 2410
This problem is mainly concerned with the volume of metal at the spark tip - if the temperature even instantaneously reaches the melting point, some of that metal will disappear. You can see that Platinum and Iridium coated plugs can withstand significantly higher temperatures, and thus can have sharper tips than their steel or copper counterparts. To add insult to injury, if some of the metal does disappear from a very sharp tip, then you've actually opened up the spark gap some. To prevent that from happening, we have to start with a wider tip, such that any small amount that is eroded will not change the size or geometry of the tip by too much.
Caveat number two: Too sharp a tip will create a "hot spot" in the combustion chamber. Even if you don't reach the melting point of the metal, you can still get it glowing hot. If that tip is still glowing red hot when the next compression stroke comes about (two full engine revolutions since the last spark) that residual heat can actually ignite the air/fuel mixture before the spark is supposed to occur. This is pre-ignition. It generally creates even more heat - leaving the spark plug even hotter than the last time thus repeating the cycle until you melt a piston. Ouch!
To avoid this, we want a wide area near the tip to conduct as much heat away from the tip as possible. Here are some of the thermal conductivities of some commonly used metals (Watts / centimeter*Kelvin) :
Zinc == 1.16
Aluminum == 2.37
Copper == 4.01
Steel == 0.70 - 0.82
Platinum == 0.716
Iridium == 1.47
You can easily see why Copper is the metal of choice for the core of the spark plug. It's just about the best thermal conductor on earth. Occasionally, you still find plugs with an aluminum core - stay away!
So, what we want is the sharpest tip possible such that it does not melt the electrode nor does it stay so hot as to cause pre-ignition. Let's break it down:
Bare Copper
They have a low melting temperature and the tips will vaporize away - they have a very wide tip so each little bit that disappears will not change the gap size greatly, but they still must be inspected often to make sure there is sufficient electrode material left. They are great for very hot running engines which must avoid pre-ignition at all costs since the wide tip will not stay hot(high boost forced induction and nitrous engines come to mind).
Platinum
Platinum plugs are usually constructed similar to copper plugs except that they have a thin coating of Platinum sputtered onto the electrode tips, about 0.010" thick (a human hair is about 0.005" thick). Because of the high melting point of Platinum, the tips can be made significantly sharper without fear of the gap changing shape. But the copper core is still sufficient to whisk the heat away fairly quickly. These are great all-around plugs, particularly for use on NA engines, and they should last a very long time. Very high heat engines should probably not use them because the sharper tips may not conduct enough heat away to prevent pre-ignition under adverse conditions.
Iridium
This is the new guy on the block. They are much like platinum plugs just with iridium in place of the platinum. Because of the extremely high melting point of iridium, they can have very sharp tips without risk of melting and they should last a very long time. These would be best for high-rpm NA engines where the sharpest tip is needed for the best spark, but there is little danger of pre-ignition.
Strange electrode geometries
For the most part - don't buy it. Splitfire (one of the originators) is undergoing all kinds of lawsuits for false claims. I won't go into detail here, but if you think about the Gauss' law thing (sharp points vs. brass *****) you really can't get any better a spark than between just two sharp points, and you're also increasing the shrouding of the spark with more or bigger electrodes.
An exception to this is retracted gap plugs ("surface-fire&quot, which are a lifesaver if you have severe detonation or plug-piston clearance problems, but they take a very powerful ignition to spark (no sharp points!) and they don't often get a good clean burn going.
Other tips
** Disregard any BS about the electrical difference of the metals - the micro-ohm difference in 0.010" thickness of Copper vs. Iridium means exactly squat when there is a huge air gap equivalent to tens of mega-ohms of resistance right there in series with it.
** When installing plugs in an aluminum head, always use a very thin (I mean thin!) coating of anti-seize compound so you can get them out later. Some plugs have zinc or cadmium plated threads, this generally helps a lot, but still use the anti-seize. Iron heads don't have this problem as much, but a little anti-seize doesn't hurt.
** Always use a calibrated torque wrench (or the precise owner's manual instructions) to tighten your plugs. Over- or under-tightening is probably the most common cause of spark plug failure.
** Buy from a reputable manufacturer that will allow you to return or exchange the plugs if you have a problem with them, many "store brand" plugs are made very cheaply, and I've seen the ceramic separate from the metal more times than I care to think.
** Always, always, err... always check the gap. Don't ever assume that the gap is correct. Do it with new plugs and every time you check your plugs. It only takes a second and it saves a lot of trouble later. In the same vein, make sure the plug in the box is what the box says it is - I've gotten the wrong plug in the right box before.
** Learn to read your plugs. Not really about plugs at all, but about what's happening in your combustion chamber. After all, the plugs are right there to witness it!
[Source: http://www.automotivearticles.com/ge...p;articleid=18]
Old Jul 21, 2003 | 12:50 PM
Bluebird's Avatar
I am Roid Rage
knight_yyz
Nov 6, 2015 02:34 PM
JoshG
51
Sep 21, 2015 10:41 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
