Questions // NX Nitrous Kit
Old Sep 23, 2003 | 12:49 PM
R1 POWR's Avatar
hello all,
i have a question about the NX Nitrous Kit from Southwest Autoworks. here's the description from the SWA website.
"Sport Compact All EFI "Stage One" Single Nozzle Nitrous System: Utilizing the patented "Shark" nozzle, these systems are fully adjustable, 35,50,75 horsepower for 4 cylinder and V-6 applications, and up to 150h.p. for V-8 and V-12 cars. These systems require no engine modifications, operate on stock fuel pumps, and require no timing retards. The ultimate solution to make your import a "Rocket". Any horsepower settings above the recommended levels require "NX Power Booster" fuel additive to prevent detonation. Kit comes with 10 lb bottle."
is this system a plug & play system? i thought you would need an ecu upgrade to run nitrous, but the description says it requires no engine mods, operates on stock fuel pumps, and requires no timing retards. it sounds plug & play to me, but i'm still a little hesitant. can someone give me the low-down on this system? what else does it require? anything? pros? cons?
thanks in advance.
Old Sep 23, 2003 | 01:38 PM
R1 POWR's Avatar
thanks moderators for moving this to the nitrous forum. sorry, i didn't know there was nitrous forum i guess i'll browse thru the stickies
Old Sep 23, 2003 | 03:50 PM
XXXL Cracker's Avatar
This is the basic kit
Originally Posted by R1 POWR
hello all,
thanks in advance.
You will also want/need:
Fuel Pressure Gauge
EGT
2 step colder copper plugs
Misc brass fitings/wiring
Purge valve
Bottle heater etc
Good luck and keep asking questions.
Big Cracker
The Frye
Sep 2, 2021 11:03 AM
pears
Sep 18, 2015 05:25 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
