How to route n20 line from engine to pillar guage?
I cant seem to find how to run the line from under the hood onto my pressure guage. where do I drill? any ideas on how to? im in the middle of the install right now.
Adam
yes. I also read that post before too. I dont remember the details but it may be that he didnt use the restrictor fitting on the solenoid manifold which slows the flow of nitrous so if it does leak, it wont blow off, it will just leak
You need to drill a hole in the firewall that's big enough to fit a 8AN line. Run it by the driveside kickpanel and up to the a pillar. It's tight but it can be done because I've done it.
