Auto spray points
Old Oct 17, 2003 | 08:51 AM
waveridr85's Avatar
Auto spray points
I have an auto and am ordering the nx kit soon. i was wondering at which points does everyone spray it? what gear ?
Old Oct 17, 2003 | 09:33 AM
Jime's Avatar
I spray in all gears and all RPM from start to finish in the 1/4.
The big problem comes from spraying at low RPM in higher gears. This never happens if you let the auto shift itself because it never drops below 4k RPM. However if you were on the road at higher speeds at low RPM spraying can be detrimental to your engine's health. Its worse for 5 speed guys because they can run really low RPM in high gears, the auto will just downshift.
Spraying at low RPM in 1st gear is not a problem because the RPM builds so fast there is no danger, its when you spray and the engine can't build RPM fast like in higher gears that causes problems.
Some folks, nitrous kit builders included say not to spray below 3k RPM but they are trying to protect idiots against themselves.
Old Oct 17, 2003 | 02:18 PM
XXXL Cracker's Avatar
I am an idiot in need of protection
Old Oct 21, 2003 | 08:22 PM
waveridr85's Avatar
thnaks mna, maybe i wont need a go button and just set it up for wot then
Old Oct 21, 2003 | 09:13 PM
greekmax2k1's Avatar
wat shot are u going to put in and are u getting the dry kit casue im most likely will get a 100 shot zex dry kit....its easy to install and its for wot only so its very easy all u do is floor and go
Old Oct 22, 2003 | 10:35 AM
waveridr85's Avatar
im doing the nx wet kit, i am starting my way at 35 and working up to the 75 as i add some more mods to handle the extra power, i plan to keep it safe by adding 1 step colder plugs, fp and egt gauges, and upgrading the fuel pump, i already did the drop resistor mod, are there any other precautionary mods i can do?
Old Oct 22, 2003 | 11:26 AM
Y2KSESteve's Avatar
Be careful with the Zex kit...
Old Oct 22, 2003 | 12:57 PM
can u please tell me why?
Old Nov 3, 2003 | 03:07 AM
Timz96SE's Avatar
I have a Zex kit, no problems here. I'm also greek, man. Get the Zex the greeks love it, lol.
gigabyte
Jan 6, 2017 06:05 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
