Nitrous and Bypass Jets?...
Old Oct 19, 2003 | 08:06 PM
Vyrus's Avatar
Just got a used nitrous kit and I am trying to make sure I have everything needed before install. The guy who I bought it from said he had 50 and 60 shot jets. I found one .032 jet (which i know is 50 shot). I am not sure where this goes or where the bypass jet is, much less where it is. Any info is appreciated.
-Cyrus
Old Oct 19, 2003 | 09:18 PM
Nismo's Avatar
they go in the nozzle before you screw on the nitrous line. the jets act as the male end of a flare fitting.
what kit is this? wet or dry? nos, nx?
Old Oct 19, 2003 | 09:22 PM
Vyrus's Avatar
N.O.S. Dry #5122.
-Cyrus
Old Oct 22, 2003 | 08:16 PM
99Maxima5sp's Avatar
Originally Posted by Vyrus
N.O.S. Dry #5122.
-Cyrus
well, if its a dry kit, then there should only be one jet, no?
Im running a wet, so i have two...
Old Oct 23, 2003 | 09:35 AM
BJJ's Avatar
BJJ
No there are two jets on dry kits, one nitrous jet and one jet in the bypass tee. To answer your original question, the bypass tee is what is going to control your fuel pressure while your spraying, it the tee that goes inline between your nitrous pressure regulator(blue cylinder looking thing that sits between the sloenoids) and your fuel pressure regulator, the size of the jst inside the tee determines how much fuel pressure is bumped up, the larger the jet the lower the fuel pressure , the smaller the jet the higher the fuel pressure.
bbsitum
Sep 6, 2019 07:31 PM
05' MaximaMan
Oct 8, 2017 06:36 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
jwright36
Sep 8, 2015 11:45 AM
