Weird Fuel Pressure readings
Old Nov 4, 2003 | 06:44 AM
XXXL Cracker's Avatar
41 PSI at idle
48 at WOT
Bad guage
Overzealous fuel pump.... I am leaning towards a bad guage, using the Automter electrical.
Anyone have a similar experience or suggestions?
Thanks,
Big Cracker
Old Nov 4, 2003 | 02:52 PM
1MAX2NV's Avatar
Which fuel pump?? If you have anything beside an OEM, your fuel pressure will be higher than spec. I just installed an AEM universal fuel pressure regulator. That will save me some $$$ on gas and get some power back.
Originally Posted by dlicari
41 PSI at idle
48 at WOT
Bad guage
Thanks,
Big Cracker
Old Nov 4, 2003 | 04:01 PM
Jime's Avatar
Just put in a $10 mechanical gauge under the hood to compare.
Old Nov 5, 2003 | 09:49 AM
1MAX2NV's Avatar
Autometer eletrical fuel pressure sender tends to go bad. Do what Jime said and just install a mechanical one under the hood to double check. I have 3 fuel pressure gauges on the car currently. One eletrical inside the car. Large autometer under the hood and a small one on the adjustable FPR.
Old Nov 5, 2003 | 12:51 PM
did you tap the line the same way? I have a fitting in there currently for a FPSS that I am not using.
Thanks,
Big Cracker
Old Nov 5, 2003 | 01:07 PM
Jime's Avatar
That'll work. Just has to be on the hi pressure side and not on the return.
Old Nov 5, 2003 | 01:09 PM
CullenJ76's Avatar
Where can i get one of these 10 dollar guages?
Old Nov 5, 2003 | 01:48 PM
1MAX2NV's Avatar
I don't know about $10...but you can get one for $15 at summitracing.com Liquid filled one too.
gustavison
Oct 4, 2015 06:50 PM
aminus21
Sep 12, 2015 04:53 PM
thenewguyy
Sep 12, 2015 11:12 AM
bennuss
Sep 11, 2015 05:55 AM
