DO i have to put a hole in my injen for nitrous?
Old Nov 12, 2003 | 01:41 PM
skandalouz's Avatar
i have an injen intake.. would i need to make a hole in it to install that little nitrous spray point?...or do i have this all wrong?
Old Nov 12, 2003 | 02:07 PM
slizan99's Avatar
your getting the zex dry kit, right? If its a dry kit, then you can get one of the air filters that has a plug in the end for nitrous.
Old Nov 12, 2003 | 02:45 PM
CBass69187's Avatar
I would tap the injen up near the throttle body if it was me, but the filter would probably work also.
Old Nov 12, 2003 | 02:52 PM
skandalouz's Avatar
if i put it in the filter... won't that be way too far from the throttle body? i thought the spray point had to be fairly close to it...
Old Nov 12, 2003 | 07:27 PM
CBass69187's Avatar
It will def. be farther than the recommonded distance, but it should still be ok if you use the filter adapter. You may also consider selling the CAI and getting a short ram to tap for nitrous, or put the filter on the end of the short ram. Just a couple ideas.
Old Nov 12, 2003 | 10:48 PM
WizzaMax's Avatar
use the threaded bung from the Zex kit and tap it four or so inches from the TB for best results...then you can plug it with a rubber stopper or bolt it shut when you dont want the Injen anymore....
Old Nov 13, 2003 | 12:10 PM
KLoWnPR109's Avatar
I've always thought that the spray should be before the MAFS. Any cons about putting it after it like it would be if on the filter?
Old Nov 14, 2003 | 06:49 AM
skandalouz's Avatar
i can only imagine how crazy the MAF would go if nitrous was sprayed before it...
matts95max
Apr 23, 2025 10:44 AM
220k+ A32
Sep 23, 2015 03:38 PM
max ride 41
Sep 17, 2015 06:17 PM
bbsitum
Sep 11, 2015 04:55 PM
maximusrising
Sep 2, 2015 09:55 AM
