newbie to NO2...
Old Dec 3, 2003 | 12:44 AM
michaelnyden's Avatar
newbie to NO2...
I am the same guy with a geforce ecu...i have talked to the guys over there and they will make 2 programs for me...the stock one made for when not sprayin and another one for when I am where it will retard my timing...in either case, I am interested in the NX kit....I don't know if I should get a dry kit or wet kit...I don't know which is better and why....? In addition, say I don't retard my timing and stay with the geforce ecu timing, if i run 100 octane, what shot will I be able to run safely? without doing any fuel upgrades? I know when running stock timing and standard premium grade octane, maxima guys can run up to a 60 shot or so without any fuel upgrades..., so with stock timing i will run a 50-60 shot, but if i keep my upgraded timing, I will run 100 octance and run what? without any fuel upgrades?
Old Dec 3, 2003 | 05:51 AM
SR20DEN's Avatar
VQ Wizard
First lesson:
NO2 = Nitrogen Dioxide (Greenhouse gas)
N2O = Nitrous Oxide (Oxidizer)
Old Dec 3, 2003 | 08:19 AM
Luquire's Avatar
Hey SR20DEN i have a question. what exactly went wrong with your nitrous setup to cause your engine to blow. were you running to lean and what kind of setup where you running(wet i think). I am really looking into getting a wet setup.
Old Dec 3, 2003 | 08:55 AM
SR20DEN's Avatar
VQ Wizard
I never said I blew an engine. Everyone else did.
I said #2 went lean and burned the piston. And I went all the way through 4 gears and part of 5 to catch a pretty fast car when I was using a massive shot.
Old Dec 3, 2003 | 09:17 AM
Luquire's Avatar
oh. i remember you saying something about there being only 2 pistons for your engine in all of the US. anyways I want some extra horsies and i trust you the most as far as nissan engine info with a nitrous setup go. so what type of kit did you by(wet or dry) and why.
Old Dec 3, 2003 | 10:05 AM
skandalouz's Avatar
i'm guessing wet... i dont think the 3.5s can go with a dry system...
Old Dec 3, 2003 | 10:36 AM
SR20DEN's Avatar
VQ Wizard
My first setup on the VQ35 was a dry system. I made a thread on how to set that up on a returnless fuel system.
Old Dec 3, 2003 | 11:19 AM
skandalouz's Avatar
ah man.. where were you 2 weeks ago sr20den.... i bought a dry zex kit + bottle heater for $200 from a friend.... i called zex and they said it wouldn't work on my car because of no fuel pressure regulator.... so i sold it and bought a new wet kit....
if only i had known it coulda been done.....
Old Dec 3, 2003 | 11:44 AM
SR20DEN's Avatar
VQ Wizard
You're actually better off with the Zex wet system because the dry setup is more expensive and complex for a returnless system.
Besides, the writeup was posted on the .org in May of 2002.
Old Dec 3, 2003 | 11:50 AM
skandalouz's Avatar
well the only reason i bought that used zex dry system was cuz it was so cheap.... i ended up buying a brand new nx wet kit for a decent price.... should be going in sunday hopefully.... if my friend isn't busy....
Old Dec 3, 2003 | 11:58 AM
SR20DEN's Avatar
VQ Wizard
Drive upto Charlotte and get it installed by me.
www.cprace.com
Old Dec 3, 2003 | 12:38 PM
skandalouz's Avatar
dude.. are u the guy i bought the autometer gauges from??? cprace sounds familiar..... i ordered some gauges through a referral by blubyu2k2
Old Dec 3, 2003 | 12:48 PM
SR20DEN's Avatar
VQ Wizard
If Blu referred you then it was Carolina Performance Racing. Im not them, I just do their Nissan/Infiniti stuff.
halfpol
Oct 17, 2022 12:16 PM
RinconI30
Nov 10, 2015 10:55 PM
JMag90
Aug 25, 2015 09:17 AM
halfpol
Aug 5, 2015 08:24 PM
ed571
Dec 29, 2000 08:04 PM
