Is spraying with bad o2 sensors harmful?
Old Dec 7, 2003 | 06:15 PM
99Maxima5sp's Avatar
I was just curious, last night before the races i threw a CEL, well i raced anyways... ...It turned out to be bank 2 sensor 1 o2 bad.
But my fear is, can/will my car possibly run too lean while im spraying and....kaboom...Or with bad o2 sensors does the car normally run richer?
Either way i know i have to fix it, but in the mean time its such perfect conditions to be racing in my neck of the woods. At the same time i dont want to be risking my motor...
Also, whats the cheapest place for o2 sensors?
Eric
Old Dec 8, 2003 | 06:09 AM
Maksim2000's Avatar
If you're sparying only at WOT, then oxygen sensor shouldn't affect anything - the car is not using them then. As far as sensors.... call DAVE B I guess. they should be like $130 a piece...
Old Dec 8, 2003 | 04:48 PM
Well yeah, i mean i would only spray at WOT. I wasnt aware that the oxygen sensors arent used at WOT, isnt that kinda dumb? Just sounds weird, i figure they would help the car from running too rich/lean at WOT...
Oh, and i found a place that sells nissan o2 sensors for like 70bucks...
Eric
Old Dec 8, 2003 | 09:08 PM
Maksim2000's Avatar
At WOT car goes into so caleld "open loop mode" because velocity of exhaust gasses past the sensor is so high it can not read A/F ratio from the oxygen sensor accurately. So the car relies soley on your MAF to figure out how much air it is getting.
It also goes in to the open loop if it suspects that the main oxygen sensors are dead.
Eric
Where ? I need one... my bank 1 sensor 2 is dead.
Old Dec 9, 2003 | 09:17 AM
SmoothMax's Avatar
OG
Cool, I didn't know that
Old Dec 9, 2003 | 05:49 PM
Good to know, thanks alot!
www.OxygenSensors.com is where they sell them cheap. Oh and oddly enough, today my check engine light went off! Ill see if it rears its ugly head again, but so far today it didnt. Oh, but i did hear a nice "knocking" sound this morning in my engine, like valves knocking . But oddly, i turned off the car, started it back up and it hasnt done it again, wtf???
Eric
Old Dec 9, 2003 | 07:38 PM
SonicDust187's Avatar
Hey man, I am about to get the exedy stage one clutch and was wondering if it holds a 75 shot in first gear and how long the break in period was?
Old Dec 10, 2003 | 08:46 AM
Hell yeah it holds a 75shot in first, if you have grip, it will hold. I allowed about 300miles for break-in, but i didnt go all out and wild till around the 500-ish mark. This clutch is just as strong as the ACT (same clutch, different pressure plate), which to my knowledge has held everything a modded max has throw its way...
Oh, and be prepared for helacious torque steer when you spray from first to second...
Eric
Old Dec 10, 2003 | 11:06 PM
danthediablo20's Avatar
nice cheap sensors
Old Dec 15, 2003 | 09:19 AM
waveridr85's Avatar
rockauto.com has cheap o2 sensors
bbsitum
Sep 6, 2019 07:31 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
conansriver
Sep 11, 2015 10:26 AM
