Leak Fix?
Old Mar 5, 2004 | 08:20 AM
waveridr85's Avatar
Leak Fix?
My bottle is leaking from where you connect the actual bottle valve to the large adapter so you can connect it to 4aa or 6aa line. It is usually bronze and has a small seal/oring in the bottm. I tried with just the oring/seal, it leaks, then i put teflon past all over the ring and threads but it just bleww all of it out, any suggestions?
Old Mar 5, 2004 | 12:31 PM
CalsonicSE's Avatar
You aren't supposed to use any sort of sealant on -AN connections. You should replace the o-ring/seal.
Old Mar 5, 2004 | 12:41 PM
waveridr85's Avatar
this isnt the an connection, this is the brass fitting to the bottle
thsi pic shows it well
its the thing on the line right beforethe gauge the braided line and the purple conector. That part is leaking with the seal to thebottle
Old Mar 6, 2004 | 03:52 AM
CalsonicSE's Avatar
Do you mean the big bottle nut connector that seals with the white teflon gasket thing? If so, just buy another one of those white teflon thingies (for lack of a better word). It's only a couple bucks. You shouldn't use any sealant on that connection either.
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
seesole
Sep 14, 2015 12:38 PM
Hdnseek
Sep 9, 2015 05:55 AM
