Can I run nitrous with my jim wolf ecu
Old Mar 17, 2004 | 03:53 PM
Shift_my vq's Avatar
Just curious if I can still run nitrous with the timing advance from my jwt ecu. Thanks guys
Old Mar 17, 2004 | 04:45 PM
Maximum96's Avatar
No 123456789
Old Mar 17, 2004 | 05:28 PM
CullenJ76's Avatar
you could get the JWT nitrous daughter board, but I'm not sure if that can just be added or if you have to have the whole ecu reprogrammed. Or you could go with a J&S safeguard.
Old Mar 17, 2004 | 05:29 PM
Vyrus's Avatar
No but if you send it to Jim Wolf again they can put a switch on the ECU which retards the timing and makes nitrous safe. IIRC it runs $400 and you have to mount the switch somewhere.
-Cyrus
Old Mar 17, 2004 | 05:32 PM
michaelnyden's Avatar
J&S ultrasafeguard....!!! it can hook up to your nitrous selenoid as an option and when it activates, this thing retards your timing....or you can get the jwt nitrous module chip if you don't mind dealing with them again!
Old Mar 17, 2004 | 06:11 PM
Maximus101's Avatar
I would not squeeze your ride with a computer mod that advances the timing. I made that mistake once on my old VW Jetta & Mister Piston decided to melt. Good thing I was slick & got the factory to cover the repairs under the warrenty!!!
Old Mar 18, 2004 | 08:02 AM
plurco's Avatar
not without the daughter board, but if you send me your ECU I will send you mine and my new NX wet kit :-)
Old Mar 18, 2004 | 01:41 PM
Ok so if I send my ecu back to him, and he reprograms it will I loose my all motor power I get from it. Or is there like a switch from spraying mode and none or something. I want squeeze bad but not blow my car up or loose my nice 14.8 second all motor et's
Old Mar 18, 2004 | 04:57 PM
Vyrus's Avatar
Yes it works on a switch. It will be geared for N/A performance like the normal ECU, but at the flip of a switch it is geared for nitrous.
-Cyrus
Old Mar 19, 2004 | 11:55 AM
C MAX's Avatar
no. just talked to ben yesterday it has to be reprogrammed and he said
at least 4 to 7 weeks. i fried my computer and tried desperateley to
get them to do one for me. sent mine to virginia instead because i couldnt wait that long...
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
