nitrous line has burn marks on it now i can't spray!!
i tried to spray when i open the bottle it started to come out a whole,when i checked it looked burned?what could of caused this.(this was in my trunk)
Originally Posted by Jime
no comprendo? what are you really trying to say?
I tried to spray and when I opened the bottle, nitrous started to come out of a hole in the line. When I checked, the line looked burned? What could of caused this? (this was in my trunk)
If its on the connector then it could just be loose or cross threaded etc but if its on the line itself then its got a hole in it and will have to be replaced or shortened and a new connector put on.
Is this a new install? Was it a used kit? Did it work ok on previous occasions?
no i found out what it was, i have a power wire for my amp in my trunk,its was cut when they broke in my car and jacked my stuff.i touched it to the line and it started to spark.I'm pretty sure it was moving around and kept hiting the nitrous line then it burned through.so i need a new line.Or where can i get it shortened?
I have seen nitrous feed lines on ebay for a reasonable price. I would make sure to pull the fuse from your power wire to keep it from grounding against anything else in the trunk. A live power wire flopping around is a good way to burn your car to the ground?
I just looked at my product catalog again and its called "fire sleeve protected hose".
part # for the 4an 6foot is 15260-FS-NOS
it might just be cheaper to just use standard stainless hose and just buy a rubber sleeve or someting and slip it on rather than buy that
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
