Just Purchased ZEX Dry kit - Questions...
Old Jan 21, 2005 | 09:20 AM
RichP23's Avatar
I bought a ZEX Dry kit on e-bay. Got a pretty good price because there are 3 pieces missing: the jets, the long stainless line, and the bottle brackets.
I had originally wanted a wet kit, but this was a good price. I've greatly researched the wet kit (through FAQ's, posts, etc...) but don't know much about the dry kit.
I'm only planning on running a 50 shot to start off with.
Questions:
1. Do I need to get one step colder or copper plugs? Will the platinum plugs do for a dry 50 shot?
2. Do I have to purchase I high flow fuel pump? I know with the wet kit I didn't have to if a was running just a 50 shot, but does the dry kit need it for such a small shot?
3. Has anyone used the ZEX Ejector Air Amplifier or know heard anything about how good they are?
4. Anything else I need to know about the ZEX kit or running a dry shot in general?
5. If I was going to purchase a wet kit, I was going to hold off on getting the fuel and EGT gauges. So, now that I'll be running dry, are they a necessary componant for this setup?
Thanks in advance!
Old Jan 22, 2005 | 04:37 PM
RichP23's Avatar
Noone...
1234567
Old Jan 22, 2005 | 04:55 PM
SonicDust187's Avatar
1) You need to get one step colder plugs.
2) Yes you do, you need a Walbro 255 high pressure pump.
3) Dont use the filter because you dont want to spray the maf on our cars. Mount the nozzle within 6" of TB.
4) I would get a FP and EGT gauge. Def get a bottle heater and a nitrous pressure gauge.
5) They are not necessary but good to have.
Old Jan 22, 2005 | 05:18 PM
RichP23's Avatar
Thanks Sonic.
Why would I need a high pressure pump, why not just High Flow? What about the 190?
What would happen if I did spray the MAF?
Old Jan 22, 2005 | 05:32 PM
RichP23's Avatar
I did some research and I think I just answered my own question about the MAF.
Old Jan 22, 2005 | 07:21 PM
If you look at the flow rating for the high flow 190 pump and the high pressure 225 pump, you will see that it is able to supply enough power for a dry kit because a dry kit uses high pressure on the fuel side to keep the car from running lean. Thus you need a high pressure pump. High flow cant support the amount of fuel at high pressure. You may be able to get away with the 190 high pressure pump but I dont think you will. Plus if you get the high pressure pump you will still need an AFR so this way you will have a lot of leaway with the 255hp over 190hp pump.
Wow thats a mouth full.
Old Jan 22, 2005 | 07:27 PM
If you contact me on AIM I can show you the flow rate. They have one here but I cant find it.
Old Jan 23, 2005 | 07:58 AM
RichP23's Avatar
You looking for the one here: http://forums.maxima.org/showthread....ght=walbro+255
I know with the wet kits the stock fuel pump can handle the job for a 50 shot. Why would it not be the same with a dry 50 shot?
Old Jan 23, 2005 | 10:38 AM
Because you will now be operating not at 43psi at wot put at 80-90psi. The stocker just cant flow enough fuel at those levels and neither can the normal 255, However only the high pressure 255 can flow at those psi. The 190HP would only barely outflow the normal 190 at those fuel levels. Thats why the 255 high pressure is needed.
Old Jan 23, 2005 | 11:09 AM
RichP23's Avatar
That means I have to get an FPR also, correct? Recommend any specific one?
Anything else I need?
Old Jan 23, 2005 | 12:01 PM
Yes, you will need one, I would ask the boosted guys which one works on maximas best. Woth the upgraded pump/colder plugs you can now spray a bigger shot.
Old Jan 23, 2005 | 12:12 PM
RichP23's Avatar
Thanks. I'll ask them. I was just saying to my gf that, since I'm getting the plugs and fuel pump, I might as well just run a 75 shot. I don't think I'd run 100 shot... 75's probably the highest I'd go.
Old Jan 23, 2005 | 12:21 PM
I wouldnt want to use a dry kit over 75 shot.
Old Jan 23, 2005 | 01:23 PM
RichP23's Avatar
What about this one:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Jan 23, 2005 | 03:04 PM
C MAX's Avatar
i wouldnt go past 70 shot dry also later you can convert to wet very simple to do. you dont need to change anything for a 50-60 shot you can use all stock parts. i ran stock plugs and stock pump for three yrs on a 60 dry shot which is what stillen recommended to me. a 60 shot will put you in the game until you learn the best results of going higher or convertng to wet.
Old Jan 24, 2005 | 02:32 PM
RichP23's Avatar
Do they make 1 Step Colder NGK Iridiums? Part Number? If so, I think I'm going to get those instead of the copper based on recent reviews.
Old Jan 26, 2005 | 09:01 AM
RichP23's Avatar
Bump for Spark plug info...
Old Jan 26, 2005 | 09:13 AM
C MAX's Avatar
heres a link for the plugs , hope it helps.
http://www.pickproparts.com/PartsLis...ategoryID=7212
Old Jan 26, 2005 | 10:19 AM
RichP23's Avatar
They don't sell NGK's and it I don't think they sell 1 step colder either.
Old Jan 26, 2005 | 10:50 AM
C MAX's Avatar
i think jime is running the ones you might want. NGKLF6RA'S
i believe. and gapped them at 0.35 and i think he's running 100-150 shot.
Mar 12, 2020 12:06 AM
doctorpullit
Apr 23, 2017 05:35 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
