Fuel questions regarding Zex kit
So I have purchased a complete ZEX dry kit along with the purge kit. I will be going to a one step colder NGK platinum plug. I plan on running the nozzle into the front of my k&n cone, similar to the zex air filter that they sell or I may drill directly into the throttle body. My question though is about fuel. Would it be wise to go with a Walbro fuel pump or can i just run the system with a FPR set at about 42-46psi? Or would I need both? or none at all? I realize that the zex system will not release any nitrous unless the throttle is a full tilt (when the micro switch has been activated) and there is enough fuel. I just want to make sure that I don't lean out. O'ya, i plan on running a 60 shot.
Thanks.
Thanks.
Thanks.
Thanks.
The Frye
Sep 2, 2021 11:03 AM
aminus21
Sep 12, 2015 04:53 PM
