HELP me understand something....
Old Aug 26, 2005 | 05:10 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
ok, there is a guy in cardomain that is runing 75x2 shot of poison..
how is this done?
is it 2 completly different systems, 2 buttons, 2 switches ect, ect..
or
is it a add on adapter that makes a single shot system a dual shot system..
so it sprays 2 shots of 75 at the same time..
help me understand.....
these are his pics:
Old Aug 26, 2005 | 05:44 PM
subs1000w's Avatar
it looks to me like a singe shot system ie only one fuel/nitrous solnoid split off to 2 nozzles. im not shure why anyone would do this because i dont see any advantege to it
i would do it so they were on separate switches so you could either have 75 or 150 worth which makes alot more sence
Old Aug 26, 2005 | 06:00 PM
Tek-Niq's Avatar
yea I'm confused...
cause why would he tell me he has 75x2 shot if they "y" out to two nozzles, wouldn't that make 150 straight up? or would it be 75 shot divided by 2 so its more like 37x2 right..
Old Aug 26, 2005 | 06:46 PM
NisMo-Max's Avatar
maybe he has it like a 2 stage system 1. that activates at WOT. 2. push Squeeze button for top end.. i dunooo? beats me..
Old Aug 26, 2005 | 06:51 PM
Jime's Avatar
If its like my 2 stage NX, it splits both nitrous and fuel to 2 nitrous solenoids and 2 fuel solenoids so that you can launch say on 1 75 shot and then when you have enough traction you engage the other 75. Its a very basic setup. You can also have it run in a 3 stage fashion, have a 75 1st stage, then a 125 second stage and then both together for a 3rd stage of 200.
However I went from that to the Maximizer which you just stick in 200 jets and program whatever you want from start to finish in each gear. Much easier but also much more expensive. You can just run a 35 shot, 50 shot, 75 etc and have numerous setups and just download whatever you want takes about 2 seconds to reprogram. It will ramp up each gear separately by % shot in time or in RPM, your choice.
Old Aug 27, 2005 | 09:57 AM
Tek-Niq's Avatar
thanx guys... I'm going to be ordering my set up during the winter, so I'm looking for different ways to hook it up..
that seperate stage thing is cool, I will look into that..
James92SE
142
Jan 2, 2024 09:23 AM
Unclejunebug
Apr 2, 2016 05:42 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
pears
Sep 18, 2015 05:25 AM
