Nitrous and Automatic??
Old Dec 2, 2005 | 02:37 AM
  #41
DonGfun's Avatar
VW = 30 MPG
Originally Posted by streetzlegend
ok now that we have that clear, which window switch do you recommend?! i kno NOS has one alot of the mustang guys use, and MSD has another. i want one i can really trust since it is a key item when activating the nitrous.
I doubt you will need a window switch ... if you start to spin and get close to red-line just take your foot off the gas ... you should have N2O on WOT switch and arming switch at a minimum ... when you come off the gas (off WOT) the N2O will stop ... you get traction ... and floor it again and hope your going fast enough now that you don't spin again. If so repeat steps above.
Old Dec 2, 2005 | 08:13 AM
  #42
mtrai760's Avatar
'Trynna' is not a word
Its easier just to be on the safe side and run one... MSD has two models now I believe, one has to be sent to MSD to be modified to work on the Max, the other I think is digital, and will work fine. The NOS one is made by MSD, save your money on the name and just get the MSD one. You can find them pretty cheap on ebay from time to time.
Old Dec 4, 2005 | 12:23 PM
  #43
streetzlegend's Avatar
Does this look like the right one? it seems a lil bit expensive. dont kno if there are others that are cheaper http://cgi.ebay.com/ebaymotors/MSD-D...QQcmdZViewItem
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
2kmaximel
Sep 16, 2015 03:19 PM
