Two quick install questions for NX kit
Old Feb 7, 2006 | 05:28 PM
the_luch's Avatar
1. Where did you mount the activation switch? Any pictures would be greatly appreciated.
2. Is the hose coming out the top of the fuel filter the one that you tap for the fuel supply?
Thanks Chris
Old Feb 8, 2006 | 07:29 AM
C MAX's Avatar
Thanks Chris
1. thats up to you personally, some hide them some put them on the steering wheel etc. mine is in my cupholder
2. that is correct the hose coming out of the fuel filter
Old Feb 8, 2006 | 08:38 AM
the_luch's Avatar
I got mixed up and I really need to know is where to put the WOT switch. Sorry, but thanks for the help with the fuel line
Old Feb 8, 2006 | 08:41 AM
xlcrew's Avatar
I’m Back
the WOT switch i put on my TB. i worked with it to make sure that it would only be hit on WOT by the piece that hold the throttle cables. check out my cardomain site i mite have a few pics there of where it's at or you could look in the stickey of installs and see them there.
Old Feb 8, 2006 | 04:20 PM
Hoooper
stickies are your friend. i plan to mount mine on the cover of my fuses. im not sure if yours is in the same place as mine, but mines just to the left and lower than the steering wheel.
Old Feb 8, 2006 | 06:07 PM
brad kay
I mounted my activation switch and DR switch both on the dash a couple inches to the right of where the steering column enters the dash itself. It was a bi tch to get in there, had to take a little of the padding or what-have-you out of the dash but i think it looks really sweet, is unnoticable to anyone besides the driver and passenger, and is conveniently close when racing
Old Feb 9, 2006 | 12:37 PM
xlcrew's Avatar
I’m Back
here's the activation switch in my car.
and then i know it's not the best pic but it's the best that i got. if you look on the TB you can kind of see where i mounted the WOT switch. hope these help you.
Old Feb 9, 2006 | 03:56 PM
Donkeypunch's Avatar
It's not a maxima but here's mine. Nothing ricey like one of those jet missle switching or bright led switch, just try to keep it looking stock.
Purge and arming.
Old Feb 10, 2006 | 05:50 AM
Ammi's Avatar
350 Detroit Muscle
quick question. NX is made to be used w/ stock fuel pressure so FPR is not needed correct?
Old Feb 10, 2006 | 06:11 AM
streetzlegend's Avatar
it is made to use stock fuel pressure. with the correct jets it will spray the appropiate amount of fuel to compensate for the nitrous. so no need to mess with the pressure.
Old Feb 10, 2006 | 06:38 AM
C MAX's Avatar
thats only if you want a shot bigger than 75 and have to change the fuel pump to the walbro, which needs a adj fpr. other than that you can stay stock.
Old Feb 10, 2006 | 08:35 AM
Ammi's Avatar
350 Detroit Muscle
so you are saying that you can get away w/out using walbro up to 75 shots?
Old Feb 10, 2006 | 10:03 AM
C MAX's Avatar
i ran 60-75 shot dry for a whole yr on a stock pump with 60,000 miles on it with no problems and with no other upgrade than a exhaust and short ram intake. im not gonna say its perfectly safe but i did it. i will say 60-70 all day long but after that you might wanna invest in a aftermarket h/l pressure fuel pump and fpr.
Old Feb 10, 2006 | 10:27 PM
most of the people that have ran up to 75shot with stock pump have been succesful with no problems and have not needed fpr. so if ur below 75shot and dont have welbro. stay stock.
Lakersallday24
Nov 7, 2024 07:31 PM
JRod28
Dec 29, 2023 09:56 PM
fulloboost
Sep 12, 2015 08:03 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
