Exhaust cutout when spraying?
Old Feb 11, 2006 | 10:24 PM
streetzlegend's Avatar
Ok, I have been thinking of putting a stock muffler back on when running n/a because i am getting annoyed and tired of my exhaust. When spraying do you guys with experience think i can get as good gains or even better gains with a cutout at the location of the Cat.... i can get a straightpipe and put a cutout on it.
Old Feb 12, 2006 | 07:53 AM
JeEvE's Avatar
I would think so, I have seen a few NA dynos that showed some gains with cutout open vs. cutout closed so with nitrous you should get better results. Do a search and see if you can come up with any dyno sheets with cutout open and closed.
Old Feb 12, 2006 | 10:20 AM
95maxrider's Avatar
Lightly modded
I remember seeing a dyno comparison on a NA car and the gains were about 6 whp/tq. I have one set up on my car, but since there doesn't seem to be enough room to fit the electric motor to open the cutout, I haven't used it yet. I need more gaskets too.....
Old Feb 12, 2006 | 05:08 PM
yea i remember someone on here with a pretty quick maxima had a Qtec electric cutout and he had some pretty good gains, Mostlikely botton end will be a lil low since theres less backpressure ,would be very beneficial at top end. but in order to get the best out of nitrous a freeflowing exhaust with no backpressure would probably be very beneficial. with my current exaust set up, and a 50shot i get exacly 50whp gain and 61lb tq gains, hopefully with the cutout i can get more out of a 50shot.
Old Feb 12, 2006 | 08:58 PM
Charcoal95GXE's Avatar
seriously qtec exhaust cutouts are a headache waiting to happen...trust me. Get one that has wingnuts and a gasket...
Old Feb 12, 2006 | 09:19 PM
may i ask why they are a headache? the one i saw on a 4th gen was huge, and 1st thing that came to my mind was "as soon as this guy goes over a speedbump too fast that cutout motor is goign to stay on the floor" cuz it was too big n low.
where do you recommend i get one with wingnut n gasket
Old Feb 13, 2006 | 03:47 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
summit
10 char
Old Feb 13, 2006 | 05:03 AM
yea i found the cutout summit offers for 21 bucks. im getting it.
Old Feb 13, 2006 | 06:42 AM
amimaxima
ya you can buy the cheap manual cutout
Old Feb 13, 2006 | 07:35 AM
i30krab's Avatar
I have the QTP cut out and I had to cut out the rear passenger side floor and raise it 4" to make enough clearance . Its been on 3 years and I've had 2 problems. The screws on the butterfly valve came loose and we welded it in place and the motor was acting up once so they sent me a replacement motor that is easy to install.
On the dyno at JWT I picked up over 20 hp using the valve.
Also, it is fun to open the valve while cruising a car show, people wonder what the hell is under the hood!!
Old Mar 9, 2006 | 02:05 PM
vq356sp's Avatar
El Mas Noob Del Org.
Does anyone have pictures of your coutout installed? i am interested in getting one soon. so far ive seen the 2 mentioned above "the manual w/wingnuts" and the "electic cut out" but i have also heared of some that are cable activated anyone have any experiences with these?
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
bumpypickle
Sep 19, 2015 01:07 AM
