Fuel pump
Old Mar 6, 2006 | 09:19 PM
99Maxxx's Avatar
Fuel pump
So I don't know if any of you have found this out, but here goes.... The aftermarket (190 or 255 lph) fuel pump for the Max is a Walbro pump for a second gen turbo Eclipse, right? Well, as it turns out, the Eclipse uses the same pump as a 95 Integra Type R. The nice thing about this is that Edelbrock sells a cheap 255 lph pump for the Integra. I believe the part number was #17937. My question is now what to do about the FPR? Do I need one thats just adjustable or do I need one that will reference boost since I'm spraying a dry shot? Thats the thing I'm curious about now. This may be a stupid question, but I'm just wondering
Old Mar 7, 2006 | 04:25 AM
Jime's Avatar
What do you mean by cheap? The Walbro is $105.
You need an adjustable FPR if you are putting in a 225 lph.
Old Mar 15, 2006 | 05:08 PM
99Maxxx's Avatar
The Walbro pump that I found was about $150, and as it turned out the "Edelbrock" fuel pump was actually a Walbro pump in the box. The same GSS342. As for the regulator, I have seen the one that JWT sells thats a adjustable stock replacement, but I think it said that it was for a Sentra. Any suggestions on that one?
Old Mar 16, 2006 | 06:46 AM
C MAX's Avatar
walbro fuel pump 102 bucks shipped (321) 722 0498
Old Mar 19, 2006 | 04:17 PM
99Maxxx's Avatar
At any rate, I've got my pump and want to know what kind of regulator I should go with. I'd like to use the NISMO regulator but I don't know if the bolt-on design will work on a Max...
Old Mar 20, 2006 | 05:51 AM
C MAX's Avatar
vortech is prety good and very simple
Old Mar 27, 2006 | 05:30 PM
nfo184's Avatar
nismo fpr??? are u talking about?
Old Mar 29, 2006 | 10:28 PM
99Maxxx's Avatar
yeah, NISMO sells a fpr....well actually its sold though JWT, but check it out http://jimwolftechnology.com/custome...asp?PartID=283
Old Apr 1, 2006 | 12:48 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
Hey with my Wet Direct port kit do I have to get a Walbro 255lph or can I stick with the Stock Fuel Pump?
Also I'm having problems with my car not being able to go over 85mph at times and then today I start the car throw it in Reverse and the car shuts off. In order to keep it from shutting off I will give it some gas. Plus, I have a engine code of 0870 better explained here->[URL="http://forums.maxima.org/showthread.php?t=464689"[/URL] Now, i'm beginning to believe that my Fuel Pump is bad and is cause my problems is this possible? Can guys shed some light? Also to add to the car shutting off when is in Reverse or Drive the car starts to shake but in park it's ok.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
