zex dry retard timing
Old Dec 15, 2006 | 03:48 AM
absoundlab
hello everyone I picked up a zex dry kit.
I have a question about retarding the timing.
I want to use a 65 hp shot. It says retard the timing -2, will the car run different when im not spraying the zex. Like as a daily driver will the car be greatly affected?
Does anyone out there have the zex traction control window switch? I was wondering how well that works.
Also is there any unit that I can buy to change timing on the fly?
Old Dec 16, 2006 | 06:23 AM
t6378tp's Avatar
Turbo 3.5
I currently have a zex dry kit and running a 65shot
I did not change anything, I just run 93octane when nitrous the higher octane gas has a slower burn and this is what allows you to run the same timing
I do plan to change to 1step colder plugs before going to a 75shot
The zex traction switch cost too much but if you have the money, I am going to get a msd rpm window switch for $80-90 or maybe used and set it around 6200-6500rpms to take some stress off the trany during shifts
as for something to change the timing on the fly let me know when you find out
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
Slamrod
Sep 3, 2015 07:38 PM
Team STILLEN
Aug 10, 2015 04:29 PM
